Spring wakeup scare
Started the beast after the winter hibernation period of Ottawa, Ontario and it made a noise on startup that has startled me. As I turned the key it made a strange noise, not like it was trying to start over, it's hard to describe, but after turning the key to the off position and trying again all was fine. It has done that twice so far, am I looking at possibly having to replace the starter ? Is there any test I can do to see if the starter is ok or not ?
Team Owner
Turn the engine over by hand does it seem to have compression?
No... then you better pull the timing covers.
Yes... then keep reading,
charge the battery ,
make sure the connections are clean,
then put the key into the ignition and turn it to the crank position.
Does the engine crank over?
I have not checked the compression by hand, but the car started on the second try, would that not say compression is fine ? The battery was on the battery charger/tender all winter, I will test the battery voltage tonight wit the tester and also I will try turning the crank to see about compression. i will also check the connection to the battery and the post connector under the hood, thank you.
I have found this in the forums:
The Multi-Meter May Be Your Best Friend When Tracking Down Electrical Problems
Here's a cool site that describes the basics in using a multi-meter:
http://www.doctronics.co.uk/meter.htm
I know how to use volt meter in general, but to test grounding points on the 928, is this how I should proceed:
Negative connector on ground point and positive on post connector under the hood ?
What type of voltage can I expect, is there a voltage which rings a bell that something is wrong, if I get 0 volts then there is a problem. Is it as basic as that ?
Sticking starter solenoid?
Team Owner
FWIW the battery tender is not a replacement for a battery charger .
you should charge the battery every few months with a 2 to 6 amp charger
Team Owner
it may just need to be put back into service,
these cars seem to run better when they are driven often
I was thinking maybe your starter hadn't quite engaged the flywheel. Those wires are super low and maybe worth a deoxit cleaning before going into hibernation again. Like you figure though, more use, less stiffness in the joints.
Hope to awaken my beast next week.
All the best
All the best
All the best
All the best
