S4 Clutch line routing
1 Post
After doing the oil pan gasket and motor mounts I'm putting everything together and I'm unsure of the clutch line routing as it passes the steering knuckle. I didn't take a picture of this.
I have the first bracket from the slave attached to the oil pan, I need to know where the second bracket goes and whether the hard line heads up to the outside or to the inside of the steering knuckle.
Pictures much appreciated.
Thanks in advance,
Lance
Thanks in advance,
Lance
Archive Gatekeeper
At the swaybar bracket:
Relative to the steering knuckle:
At the oil pan:
Here's kind of a schematic of the whole thing, viewed from the front:
At the oil pan:
1 Post
Rob,
Thank you I actually broke the weld nut on the sway bar bracket when I was removing it. At that point I forgot about the clutch line bracket. I've long since welded the weld nut back in, but only now when I saw your picture did I remember how I broke it.
Thanks again,
Lance
Thanks again,
Lance
