928 Forum 1978-1995
Sponsored by: 928 Specialists
LED troubleshooring
Old Mar 18, 2015 | 09:20 PM
sstrickstein's Avatar
sstrickstein
Originally Posted by FLYVMO
Make sure you get the electronic flasher with the correct pins on it..there are a couple of different versions out there. I bought mine from SuperbrightLEDs.com and it worked perfectly on my 86.5. The first electronic flasher relay I tried did not work because the pins on the relay were not the same as our 928 relays...second time around I got the correct one, and it worked. As mentioned, the company above knew which one to use. Unfortunately I passed it along to another Rennlister so I can't send it your way.
Cheers!
Carl
I have one of those relays coming from Superbright LEDs. I got the resistor kit from them for the headlights. No flashing with the fog lights on any more! Job done. Now on to the brake lights. I really don't want to hack into the tail light wires to install a resistor at each tail light. It would either have me pulling the bumper cover or the interior panels under the rear windows. Either of which is both not fun and not a good place for a resistor. So I think I am just going to pull the bulb in the IP for the brake warning. OR as was suggested bypass the light module where the wire comes from the peddle. Ill keep you in the loop.
Old Mar 19, 2015 | 02:38 PM
sstrickstein
I installed a CF13GL-02 flasher from www.superbrightleds.com and now have working turn signals. The indicator in the dash lights very dim, but I can live with that. Now to handle the brake light warning in the dash.
Old Mar 20, 2015 | 02:21 AM
sstrickstein
Did some reading of old posts on this forum. It seams if I pull the plug that goes into the lighting controller and take it apart, I can pull the wires that lead up to the IP and disconnect the brake warning bulb wont be lit. Pulling terminal 6 or 8 out of the plug.
