SLOTTED SHIFT KNOB
FUNCTION-FIRST Performance strives to reconnect drivers to their vehicles with the new SLOTTED SHIFT ****
Our Slotted Shift **** is machined from solid billet 6061-T6 aluminum to ensure that all shifting effort is transferred to the shifter, not lost to a flexing shift ****. The 2-inch diameter fits firmly in the palm, and is spaced high up to keep the shifting hand clear of the shift boot. The **** is designed specifically to fit Porsche’s rectangular shifter shaft, and attaches securely via high-hold cone point set screws. Mounting height is customizable, ranging between 0.25-inches lower and 1-inch higher than stock.
The distinct slotted design reduces weight and delivers a no-slip grip, all while effectively shedding away the heat that commonly plagues standard billet shift *****.
Shift boot integration is not an after-thought. Our unique collar affixes the shift boot cleanly under the base of the **** - it does not “puke” out the top, as with other aftermarket and early OEM shift *****.
Two color choices:
Silver (clear anodize)
Black (black satin anodize - available March 9)
Fitment is for manual transmission vehicles only.
Please click here to check out the product page for additional pics, details, and installation instructions.
Comprehensive Shifting Solutions for your Porsche.
Thanks!
For those interested, here's the process and design considerations behind the development of the Slotted Shift ****:
Next time you're in your car, grab the shift **** firmly, and twist it clockwise and counterclockwise. For most setups out there, you'll find that the **** will flex, and in some cases quite a significant amount. With the older cars, specifically, there are rubber insulators between the OEM **** and the shifter shaft that serve to dampen drivetrain noise and isolate the interior from the solid rod shifter linkage. Bolting a billet shift **** directly to the shifter shaft will eliminate that play and flex.
From here, I'll speak from a personal point of view, which should give you a better glimpse into why and how I tackled designing this upgrade.
Early on, I purchased a solid billet ****. Immediately after installing it (and changing nothing else), I experienced much more direct and confident shifts. It reduced the flex and play originating in the plastic/rubber OEM shift ****.
However, I ran into a few problems with that billet **** that I wanted to solve in my own design.
Problems experienced:
1) Slippery - with some aggressive 1-2 and 3-4 shifts, the **** would slip out of my hand
2) Temperature sensitivity - the **** would get very hot in summer, and very cold in winter; worse yet, it would take an extremely long time for it to equalize with ambient temperature
3) Shifting hand would contact the shift boot - the shift boot interfered with the base of my shifting hand
4) Poor shift boot fitment - the mechanism by which the boot attached to the **** caused the boot to extend upwards before folding down, which exacerbated Problem #3 above, and it looked very unfinished
Solutions implemented:
1) Slotted cutouts - provides a no-slip grip
2) Slotted cutouts - less material mass at the ****-to-hand contact points retain less heat, and "fins" speed up temperature equalization
3) Raised shift ball higher - along with the thinner shaft below it, raising the ball higher up the shift **** ensures the shifting hand is fully seated on only the ball itself
4) Shift boot collar design - the separate collar design, along with the flared out base of the shift ****, ensures the shift boot sits below the entire shift ****, also delivering a much cleaner look
In 1984 in the U.S., kinda true, but overall from 1980 to 1995 roughly 1/3 were 5-speeds. This dataset is incomplete and missing about 500 mid-year cars, but close enough for market analysis purposes.
I like the look of that shifter, kind of evokes the balsa shifter on the 917.
Sorry, I don't currently have any pics of the Shift **** in a 928.
If you wanted to reuse your shift boot from the integrated OEM shift ****/boot, you would have to cut the boot off. Take a look through the Installation Instructions at the bottom of the product page for full pics and details on the install process.
I am very interested in this for my 86. However, I too am skeptical as it has not been done (or pics at least) on a 928 yet. I love the idea, and if you are looking for a tester please PM me. (I have a lot of product testing experience!) As said previously, the shifter and boot on the 928s is not normal by any standpoint and hard to come by/expensive for a replacement. I look forward to hearing more though and let me know if you are interested in working together on this.
Thanks for all the feedback, guys!
The black Slotted Shift ***** just came back from the anodizer and are now in stock. They did a real nice job with them and I think they turned out awesome! It's a stealthy and subtle look for your interior.
