928 Forum 1978-1995
Sponsored by: 928 Specialists
the shifter became inoperative...
Old Aug 31, 2003 | 06:17 PM
kelli's Avatar
kelli
Default the shifter became inoperative...
OK, bare with me here, not sure if I have all the correct terms...
While driving, the shifter became inoperative...
Stuck in second gear. After stopping managed to get it into 4th to limp it home.
Undernieth the shift **** boot theirs a shaft connected to the linkage that runs forward, it appears that the front of this shaft has become disconnected from it's anchor point
Need to know how to access the linkage shafts forward mount to reconnect
Anyone of a shop manual for this, or suggestions????
my car is a 1988 928 S4, 5speed
Thanks ahead of time for any help on this
Kelli
Old Aug 31, 2003 | 07:02 PM
John Struthers's Avatar
John Struthers
User
928 INTL actually has the step by step procedure as a sidebar in their catalogs.
I don't have a scanner - It's simple but long- so I can't help you -sorry-.
Maybe someone near you has a copy to lend you or can scan upload and E-you.
Check the Greg Nichols site -add site to favorites-.
Old Sep 3, 2003 | 02:49 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
It is the shifter ball cup. There is plenty on the subject here. I just did mine and posted the steps in detail. Search under shifter ball cup. BTW there is a neat trick where you use the 928 jack to seat the ball cup. Otherwise it can be quite difficult.
Old Sep 3, 2003 | 06:54 PM
Sean79 5spd's Avatar
Sean79 5spd
Check the bushings in the rear coupler while you are at it.
Old Sep 3, 2003 | 08:11 PM
John Struthers
User
Scuse',
The sidebar write up in the 928 INTL Catalog describes the ball/cup replacement - in depth-.
The article was written by Kurt Gibble.
Maybe Jim Bailey can help with the upload.
Good luck
