928 Forum 1978-1995
Sponsored by: 928 Specialists
Tap and Dye question
Old Aug 30, 2003 | 12:46 AM
checkmate1996's Avatar
checkmate1996
Question Tap and Dye question
This is a general auto question:
Would anyone be able to point in the right direction on how to use a tap and dye kit? Web link? etc.
Thanks in advance for any replies.
Old Aug 30, 2003 | 12:52 AM
User 4221's Avatar
User 4221
Good question...... I learned by tapping stainless.... A real PITA. That means breaking many taps.
The general technique is used on all metals but speed and pressure are material dependent.
What type of material are you planning on working with?
Old Aug 30, 2003 | 01:20 AM
Thom1's Avatar
Thom1
http://www.mcmaster.com/
Old Aug 30, 2003 | 02:19 PM
T_MaX's Avatar
T_MaX
K&K
MM
Old Aug 30, 2003 | 02:59 PM
checkmate1996
Great stuff folks. I appreciate it!
Old Aug 30, 2003 | 03:53 PM
V-Fib's Avatar
V-Fib
We had a choice?
Buy the best ones you can afford. A good set will last you a lifetime and then some. A set can range from $9.99 to $500.00. I got a new Craftsman set on Ebay for $99.00. Considering it was a $279.00 set, a fair deal. Use proper cutting oil and use the correct size drill bits if you're tapping a new hole. A Numbered drill bit set is mandatory for many sizes in SAE and Metric. Take your time, pre-think every step and you can fix just about any problem you will come across.
Anthony Tate
79/928 Silver Metallic
