928 Forum 1978-1995
Sponsored by: 928 Specialists
Outlaw Bushing
Old Feb 16, 2015 | 04:46 PM
Ladybug83's Avatar
Ladybug83
Default Outlaw Bushing
Scratching my head on this one, thanks in advance for any insight.
This morning I reinstalled my new clutch master cylinder after cutting the piston from 80mm to 75mm. Also installed my brake booster and hooked up all the linkage for the brake pedal and clutch pedal. After finishing the install, i was accounting for the hardware remaining in the baggie marked "Clutch master cylinder" and found this bushing. The remaining hardware in the baggie is for the slave cylinder, line clips, etc. But I can't for the life of me figure out where this bushing came from. Been searching the manual and the PET and I just can't find it anywhere associated with the clutch and/or brake hydraulics or pedals. I got the two spacers in place on the firewall at the CMC, this one looks similar but about half as long. Pedal action is good, nothing loose. Pics below, 12mm length, 17mm OD, 11.5mm ID. Look familiar to anyone? Thanks again, Josh
Old Feb 16, 2015 | 05:26 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Spacer for the bolts that goes between the firewall and the mounting bracket so you don't "squish" the padding.
Old Feb 16, 2015 | 05:28 PM
Ladybug83's Avatar
Ladybug83
Yup got those two in place correctly. This one is similar but about half the length of the CMC spacers. I'm wondering if it's from the pod, dash, or something close by and it got mixed in with the clutch hardware during disassembly
Old Feb 16, 2015 | 05:52 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Durp, missed where you said you had them already......
Old Feb 16, 2015 | 06:19 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
I should know, but I don't- is there some sort of package tray or knee bolster on an '83 on the driver's side? Maybe that's a spacer for mounting said tray (?) There's a similar (though thinner walled) spacer for the knee bolster on airbag cars.
Old Feb 16, 2015 | 07:02 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
that looks like a bushing/spacer that goes on the clevis pin at the top of the clutch pedal
Old Feb 16, 2015 | 08:25 PM
Ladybug83's Avatar
Ladybug83
Default Got it
Thanks guys, figured it out. Ill tell you if you wanna know, but lets make it interesting. I won't give any more clues other than it is in the PET.
I have a Baron 852 Porsche crest leather stamp that goes to the winner (picture below). Its @ 33mm x 21mm. I have tried my skills with it and decided Im not gonna use it (its tricker than it looks) so it will be awarded and shipped to the first Rennlist member who answers correctly. I hope the winner uses it, or passes it to someone who will because it's a cool little piece and I hate to see it collecting dust on my shelf.
So far, here's where we are:
Duc answered - CMC
Rob answered - shelf/knee pad thingy
Stan answered - clutch pedal clevis
First correct answer wins. Happy Presidents Day
Old Feb 16, 2015 | 09:00 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
well shux that bushing looks like it has been clamped offcenter its not for the clutch pedal clevis.
Could it be a spacer bushing for the brake booster?
Old Feb 16, 2015 | 09:03 PM
Ladybug83's Avatar
Ladybug83
That's correct, clutch pedal clevis takes a plastic sleeve bushing, at least in '83.
Old Feb 18, 2015 | 08:49 AM
Ladybug83's Avatar
Ladybug83
OK Times up.
This is one of the seatbelt buckle spacers. Must fallen down and got mixed in with the CMC hardware. Sorry for the confusion and thanks for the help figuring it out.
As for the leather stamp prize, I suppose Ill keep it for now. If anyone needs something stamped, let me know :P
Old Feb 18, 2015 | 09:34 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
well that was good,
one of the few parts I didnt recognize .
And with your prompting now I do.
The stamp looks like a cool tool
Old Feb 18, 2015 | 09:44 AM
Ladybug83's Avatar
Ladybug83
well that was good, one of the few parts I didnt recognize . And with your prompting now I do. The stamp looks like a cool tool
PM me your address and its yours
Old Feb 18, 2015 | 09:55 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Thanks again,
PM sent
