928 Forum 1978-1995
Sponsored by: 928 Specialists
Chasing a no-start 1988 S4 Manual - Updated
Old 03-03-2015, 07:17 AM
  #76
worf928
worf928's Avatar
Received 1,624 Likes on 1,061 Posts
Originally Posted by John Speake
There may also be a heavy current drain is you needed that much grunt to hold up the battery voltage (or the battery is toast)
I agree. Something is shorted. It's factory-installed smoke will soon be vented. And possibly be accompanied by rapid exothermic oxidation.
A voltage-drop test during cranking (without LH killer hooked up) will tell all.
Also, those jump starters typically put out 14+v. That's enough that it can mask a bad/slightly-floating ground to a component or subsystem.
Old 03-03-2015, 12:00 PM
  #77
Kevin in Atlanta
Kevin in Atlanta's Avatar
Originally Posted by worf928
Your debugging process is not focused. Concentrate on spark first. And spark only. Disconnect fuel-related components: LH, LH relay, etc., to get them out of the circuit. Make the electrical system as simple as possible through disconnection and removal. Remove fuses, relays, etc., until only stuff needed to make spark work is connected. Make spark work. Then begin reconnecting bits.
You have to decompose this problem into manageable bits.
+928 on my debugging process!
The LH computer is fine - I used another 87 to test it.
I will pass your advice on to my electrician who is going over the car now.
Old 03-03-2015, 12:34 PM
  #78
Kevin in Atlanta
When I bought the car besides the non-start the anti-lock warning is lit with the key on and central warning system brain was fried. Is there a possibility the anti-lock and the non-start are related? I need to look at the steps to diagnose that while my electrician does his thing.
Old 03-03-2015, 03:07 PM
  #79
fraggle
fraggle's Avatar
If you have your PC Oscope, you can test the tach signal/cps from inside the car by putting a probe in the backside of plug W. I think it is pin 23. You should be able to verify the pin outs in the WSM. That signal goes from there to the tach. The advantage here is you can monitor everything in "as connected" state.
You can also remove the tach from the circuit non-destructively by removing that pin from the connector. Use a pin pusher and no damage will occur, and is easily reversable.
Old 03-04-2015, 12:43 PM
  #80
Kevin in Atlanta
Originally Posted by Hilton
If you have a laptop (or other small windows powered device) I recommend getting a 2-channel USB digital o'scope. Having a second channel comes in handy a lot, and the ability to run on a laptop means taking screenshots etc. is easier.
I've had a Hantek one for a few years - the equivalent of their current 2000-series. Mine is equivalent to the bottom end (DSO-2090 - 40MHz total, so 20MHz (50MS/s) per channel) - altho' I have found lately I'd like one which can work at radio frequency levels (for testing/calibrating old hifi tuners), so at some point I'll upgrade.
You can pick up their cheapest model, the 6022BE for less than $70 on ebay, and it has quite a following on eevblog, including open-source-developed software for it which improves on the stock hantek stuff:
http://www.eevblog.com/forum/testgea...z-usb-dso/810/
Broke down and ordered via Amazon.
Old 03-04-2015, 01:54 PM
  #81
bureau13
bureau13's Avatar
I suspect your ABS light is a blown fuse (something else may of course be blown as well). When I replaced my blown fuse, the ABS light stays off until I've driven a short distance, at which time I believe the lack of signal (I'm presuming this is due to some severed wires by the left front wheel) is causing the light to come on.
Old 03-04-2015, 02:22 PM
  #82
Kevin in Atlanta
While I wait for the oscilloscope to arrive I am going to follow mrmerlin's suggestion and look at the power and ground connections at the fuel pump. I find it interesting that with a strong charging the fuel pump comes on and stays on with the key in the start position and and sometimes pulses when I move the key into the on position just on battery power. I know the PO replaced the fuel pump and cleaned the tank and I see there might be an in-tank pump as well. I did clean the grounds in the spare tire well. Time to get it in the air.
Old 03-04-2015, 02:49 PM
  #83
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,471 Likes on 1,390 Posts
if you have an intank pump,
it would be a good idea to pull it out and inspect the short hose as they are know to come apart and then take out the 044 pump.
You can replace the short hose and renew the clamps ,
or just swap it out with a fuel strainer.
NOTE its installed to reduce the vapor lock issue.
If you do have an intank pump pay attention to how it may be wired,
it could be shorted
Old 03-06-2015, 01:32 PM
  #84
fraggle
fraggle's Avatar
Do you have the official Porsche EZK/LH training and troubleshooting guide? It is a nice essential for situations like this. I've used mine a lot over the years. It has. The best details for troubleshooting and some of the nicest wiring schematics for refence.
Old 03-06-2015, 01:38 PM
  #85
Kevin in Atlanta
Jim's CDs are in the mail.
Old 03-06-2015, 04:26 PM
  #86
worf928
worf928's Avatar
Your electrical system has issues.
Duh.
Putting 40A into a system with issues is going to cause more issues if it hasn't already. If you have a known-good fully-charged battery and cannot keep > 11 volts during cranking to the fuse panel then that is the first thing to fix.
Your LH is fried or someone has wired a bypass around the FP relay (I've seen that before.)
Pull the fuel pump relay. Disconnect the LH.
Wait for the CDs to arrive. Use the LH/EZK troubleshooting guide and first figure out why you have no spark. If you don't have spark you will never have fuel - unless FP relay is bypassed. You will certainly never have injector pulses without spark unless your LH is fried. That is how the system is designed.
Once you have spark, then worry about fuel.
Old 03-06-2015, 05:59 PM
  #87
Kevin in Atlanta
Worf928 - Agreed. Waiting on the o-scope and the CDs. The computers are fine.
You are probably right - I just need to document what I have. Keeps me busy while I wait for the CDs and o-scope.
Old 03-06-2015, 06:17 PM
  #88
Sapientoni
Sapientoni's Avatar
Default fuel pump tricks
I had one that got water in the system and after the cleaning (of the water removal while hot and subsequent fire damages) the fuel pump was making noise like it was working, but it was frozen and just vibrating. It sounded for all the world as if it were working. Check fuel delivery and good luck.
Old 03-06-2015, 07:09 PM
  #89
Kevin in Atlanta
While going through my list I noticed the volts from the 30 to the 87 on the LH Relay is 11.78v and 30 to ground is 12.22v. The other three deadly relays are 12.22v~ from 30-87 and 30-ground. Another interesting thing is that without the computers hooked up the LH 30-87 was 10.78v.
Added: After jumpering the LH relay I get 12.14v at LH Connector pin # 18.
Added: After jumpering the FP relay I get 11.62 at the fuel pump fuse.
Old 03-07-2015, 03:27 PM
  #90
worf928
worf928's Avatar
If you have observed that the LH from the sick 928 does not activate the FP relay - and therefore the fuel pump - when connected to a healthy 928 with the key in the on position, then someone has bypassed the 85/86 terminals of the FP relay socket in the sick 928, either directory or indirectly.
If indeed your FP runs with the key in the 'on' position with a known-good LH then that is where I would start: why does the FP relay activate with the key on? (Or perhaps the FP circuit itself has been hacked to bypass the FP relay.)
And that's not right. They should be virtually the same.
Have you done a static current draw test on the battery?
Have you examined all the wiring into the CEL panel plugs?
Have you unbolted and flipped-down the CEL panel to look at the back side?
If there is no obvious sign of damage to the CEL, no 'extra' wires hacked-in to the FP relay, etc. Then one thing to do is to study the wiring diagrams for the LH relay circuit so that you know which CEL panel plugs to disconnect so as to break the circuit into branches. Then you can test each branch by itself.
Quick Reply: Chasing a no-start 1988 S4 Manual - Updated
