Tires for those of us with 16in wheels...
Pre-S4 have 16x7 all round. All of them have 225/50/16 all round. (other than some early auto phone dials with 15" wheels)
These all have 225/50/16 front, 245/45/16 rear:
87-91 S4: 16x7 16x8 (forged)
90-91 GT: 16x7.5 16x9 (cast)
CS/SE/89GT: 16x8 16x9 (forged)
That's why I'm confused...the car is an 89 S4...with optional platinum wheels from the factory...guess they are 225 all around.
Unless someone replaced them with a less-scratached set from an earlier car (platinum metallic wheels are way more common on the 928S).
I am using bridgestone comp 2 in 225/50/16 and 245/50/16. My rims are 8 inch front and 9 inch rear. I was thinking of putting the 245/50/16 on the front and 255/50/16 on the rears. The 255 is about an inch wider...than the 245. I think they will fill up the wheel wells better
You clearly have the 16x8 rears which should have 245/45/16 tyres on them
The shape of them is different - the flat part is inset, unlike your 16x7 fronts. The option code info is a throwback to the early cars (where they are 16x7 all round).
the reason for asking is that it would seem that the fronts would have a greater side load in a turn even with a 50-50 weight distribution. they are angled more than the rears. I'm discounting any accel/decel factor. -I don't consider a 928 a serious drag car so big rears would not enter here either. fwiw I consider toy (fake) muscle cars with teenie fronts and humongous rears an abortion.
I would not recommend 225s on an 8" rim but as I said 245/50-16 fits great and is a common enough size. I bought a car which had 225s on 8" clubsports and the curb damage was quite dismaying.
1)The BFGoodrich 245/50R16 g-Force Sport has a diameter of 25.7" and a width of 9.6", it is mounted on a 16" rim with 785 revolutions per mile.
2)The BFGoodrich 245/50R16 g-Force Sport COMP-2 has a diameter of 25.7" and a width of 10", it is mounted on a 16" rim with 810 revolutions per mile.
3)The BFGoodrich 255/50R16 g-Force Sport COMP-2 has a diameter of 26.1" and a width of 10.4", it is mounted on a 16" rim with 798 revolutions per mile.
Here is the link where I've pulled this info from...http://tire-size-conversion.com/tire-size-calculator/
Just bought the Toyo T1R 16" set
I have driven on these on a number of MBs, and liked them just fine. I actually won't be needing them for quite a while, but they were so hilariously cheap for such a "correct" tire set that I had to get them. From Tire Rack, $550.00 grand total at my door. They are on "close out" status, so if you think you may want a set you may want to act soon...
