Injector o-ring seating MY91
The picture I snapped are after I tightened the fuel rail down.
The last picture is number 4 cylinder and it is seated lower than all the rest.
I am a paranoid about leaks...
I would need to go to the garage and take a look at mine but quite sure there're not that high.
You did not put the rubber spacers on the stud that you talked in the other thread before putting the fuel rail, right?
Second picture looks better though blurry.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
The correct order of operations is:
- install injectors into rails
- attach clips
- wiggle/tug each injector to ensure that the clips 'click' into place
- install fuel rails, lower o-rings will take firm pressure to insert into bores
- tighten dampener and regulator nuts and rail nuts
- remove fuel pump relay and bypass to pressurize rails
- check for leaks
There shouldn't be any weirdness with the installation. Do not put the injectors in the bores and then try to install the rails (*)
Never, never, ever skip the last step. And do it well before you want to start the car. Ideally do this as soon as you've closed-up the fuel system.
* lower o-ring leak is false air, upper o-ring leak is a car fire.
