Smog Pump - remove front pulley - pics od disassembly
A while you were in there project.
My smog pump on my S4 was rough. I just removed the belt, and not a big deal. Since It was so easy to inactivate it, but now I decided to take it apart. I searched, and did not find pics of what the inside looks like since I think most people just remove them.
Anyway, how can I get the front disassembled. I need to pull the front Pulley holder int he first picture. I am thinking I have to make a puller by screwing into the plate, and then using a center screw to pull it out.
Sorry about the blurry pic of the inside. Interesting design with the eccentric shaft.
What I did was bolt some thick washers to the plate with short M6 bolts. Then use a 3-jaw puller hooked under each washer for purchase. If you don't have handy washers, you could make some tabs with 6mm holes out of steel plate.
Archive Gatekeeper
Mark Grasser has a page on his RL member site RE: air pump rebuilding. Interestingly he didn't take many disassembly pics either but he does describe the tool he made to get the front bushing plate off:
http://members.rennlist.com/mgrasser/airpumprebuild.htm
