What grade of fuel
#31
Less than a year into 928 ownership in the late 1990's, I was driving back to SoCal from a Devek event, hot August day. I stopped for fuel and accidentally put regular into my S4. Even with all the spark-retard and knock-sensing systems intact, it still complained with a few audible pings and continuing poor performance. I drove it gently for the rest of the ride home (maybe 50 miles), and ended up transferring most of the remaining fuel to my other less picky car's tank.
Fast-forward to today. Fuel quality here in Oregon is much better than what is available in southern California. Mileage is much better here, some because of lack of traffic I'm sure, but mostly because the fuel blend is much better. I've only passed a couple tanks of fuel into the 928 since arriving here, still enough to see 22-25 MPG average results. The Honda has done much better too, with mid- to high-twenties mileage here vs. high teens in SoCal. I have an OBD onterface set up on the Honda to datalog to my tablet. One of the available parameters is the sensor that reads the amount of ethanol in the fuel. In California it showed around 12% most of the time, but sometimes showed as high as 20%. Mileage was affected almost directly by this number. Local fuel here shows no ethanol at that sensor, and mileage has improved by some 20-25%. Again, driving patterns have changed too, so I can't attribute it all to the fuel.
On other past "regular gas " cars with knock and exhaust oxygen sensing, premium fuel would often more than pay for itself in improved fuel mileage. I'm pretty religious about tracking miles and costs, and with the increase in gas costs over $3/gal even the "just needs regular" cars would improve enough percentage-wise to justify the extra twenty cents fer gallon for premium. The cars also saw mileage and performance improvements with new oxy sensors, easily enough to justify replacement every 40-50k miles.
#33
Did you have some serious mods to the heads and timing or possibly running a lot of boost?
110 octane aviation fuel puts out the same btu per gallon as 87 pump gas...112K to 114K BTUs per gallon depending on the brand.
Even Sunoco 110 racing fuel is rated at 113,400 btu/gallon.
#34
too funny placebo effect.... since higher octane fuel burns SLOWER and carries no more energy it simply does not explode as FAST !!! it is WOW I put in this expensive gas it MUST run better....
later 87 > 928 the smart brains will compensate for low grade fuel BUT big BUT they have no way to adjust for "race fuel" that requires reprograming for more advance. Early cars have no idea what they are being fed and have no way to adjust....
#35
#36
But then, due to my fabulous *Autothority* chips my city mileage is horrible no matter how you skin the cat.
Ordering the Porken chips any minute now. . .
#37
Chronic Tool Dropper
Here in the Central Valley I find the winter mileage is really up and down. I often find the mileage improves in winter, probably due to the ideal operating air temp and not running A/C, but then at some point the gas blend does change or something and the mileage suddenly drops by about 1 mpg at some point during the winter months. The best mileage is during late Fall when temps are ideal, A/C is not running, and most stations are still pumping "summer gas."
And Sean, are you sure you actually have Autothority chips in the car? I installed the rebuilt LH in the car when it was Rolf's, and we didn't do any chip swapping that I remember. Of course they may have been in the brain we swapped in... Rich Andrade did the brain fix on it, should have a sticker on it from him. I don't remember if I just swapped my rebuilt spare '88 brain into the car or swapped his old one back in after it was repaired. If it was my spare, it has later full diagnostics in it.
