Cooling pipe inside radiator
Basic Sponsor
Just had time to check availability - 14 sitting in Germany and that's it.
Vilhuer,
Save the 50 euros ..... I made & installed one in 2004 for far less than a Euro: .... see rad diffuser ( actually titled 'flow promoter')
Cheers
PS: it's still in there a decade later.
Cheers
I'll probably pull one out from some old factory radiator we have in garage for alu rad I have waiting for green GTS to be ready in few years.
Chronic Tool Dropper
FWIW, if I needed one of these I'd be attacking an aluminum food can with snips to make one. It's already pre-formed into a round shape. Something thicker than a beer can for sure, but it really wouldn't take much more than that to get the job done.
Source for thinwall aluminum tubing here-
lots of size choices- what do we really need?
1 foot should make a few including mistakes:
http://www.onlinemetals.com/merchant...p=2&top_cat=60
^^^ This one's the closest ... 1.5" OD x 0.035" WALL x 1.43" ID 2024 T3 TUBE
The standard part is thinner though, with a 0.027" thickness. It's really not an issue to cut out and roll form some flat sheet, which is more commonly available, and in small pieces. I've used lots of that material to form round, oval and tapered brake cooling ducts ... making one of these would be a piece of cake.
