928 Forum 1978-1995
Sponsored by: 928 Specialists
How to remove the footrest
Old Jan 1, 2015 | 02:25 PM
Ad0911's Avatar
Ad0911
Default How to remove the footrest
Before trying, I wondered if anyody has ever removed the footrest from the drivers side from a car with the steering on the left side. What is behind it? I want to checkit for rust
Old Jan 1, 2015 | 03:36 PM
joejoe's Avatar
joejoe
later cars has abs computer I believe. Not sure for early cars.
Old Jan 1, 2015 | 03:47 PM
FLYVMO's Avatar
FLYVMO
The central warning computer is located behind the foot rest. For later cars with ABS, that unit is mounted above the foot rest. To remove the foot rest, remove the thumb nut, the pull the foot rest upwards, then towards the rear of the car. Need to disconnect the central warning computer harness connectors before it can be removed from the car.
Cheers!
Carl
Old Jan 1, 2015 | 03:55 PM
Ad0911's Avatar
Ad0911
Cheers!
Carl
I think the central warning box is in the right footwell if I recall correctly
Old Jan 1, 2015 | 04:39 PM
FLYVMO's Avatar
FLYVMO
Nope
It is mounted inside the driver's foot rest, at least on every '80 through '87 928 I have seen. The ECUs (LH and EZK/EZF computer is located in the right (passenger) footwell. For a RHD car I do not know. The bulb check unit is in the passenger footwell, attached to the lower parcel tray.
Cheers!
Carl
