How Possible to Swap BMW M5 V10 with SMG transmission in 928 ?
i think this V10 is rev to 8000 and 507 HP in porsche 928 is very nice combo
how possible it fit in Porsche 928
------------ Thank you
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Buy a Twin Turbo Kit from John Kuhn. Up to 700 HP at the wheels for less money.
http://www.kuhnperformance.com/model...928-twin-turbo
https://rennlist.com/forums/928-foru...e-streets.html
Åke
Åke
Alternatively you can put in a E8x 6spd box and use a Pectel ECU. However, the ECU alone is $16k. Still feeling rich and optimistic?
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Step 1) Measure. The chassis engine compartment needs width of engine plus working room, length plus radiator. Need to plan for exhaust routing to miss steering rack, frame rails, etc. Not every motor will fit every car, for example the Cayenne and Panamera V8s are too wide for a 928.
Then move to trans tunnel - will SMG tranny fit? This is a harder measurement because it's not a simple rectangular space, it's a lumpy conical shape.
Often the only way to see if it fits is to get the chassis on the lift and the proposed drivetrain underneath it and squish them together.
2) Supposing it fits, custom fab time. Either you have a pro-level shop in your garage AND pro-level skills in the complicated engine-swap game or you pay $$$$$ to someone who does. We're talking engineering, welding, and fabricating - nothing will bolt right in. Poorly planned and executed engine swaps either become never-ran parts cars or burn to the ground.
3) BMW does not make modular component cars nowadays, they make complete systems. When you swap an LS1 into a car/truck/riding lawnmower you simply run power to the stock GM ECU which is a single-pupose modular component. But the modern BMW ECU is a central master control system tied into EVERYTHING: ABS, climate control, nav system, rain-sensing wipers, seat warmers, tailight bulbs, the SMG tranny, etc. Not hooking up any of those things will cause problems for the computer. So you're essentially looking at a lot of custom electrical work and maybe aftermarket ECU programming. The SMG in particular will be a thorny problem.
So: are you done daydreaming yet?
