Winter project info request 89 S4 auto
Starting first winter project which is replacing all the ATF hoses in the front of the car as rears were already replaced. I know #7 is leaking and since I stored it 2 weeks ago I know I have ATF leak on drivers side too.
Can someone please provide hose sizes/type or possible a location to purchase a hose kit so I can stage parts prior to starting.
Strange thing also happened....drove all summer(6K miles) with no visual coolant leaks and 2 weeks after sitting in garage my radiator has formed a leak somewhere on the drivers side. I will be removing it and getting it tested which I think will make hose replacement easier. The radiator is from 928MS and was installed in 11/2010 should it have failed already?
I will also be replacing fuel lines at the same time (getting kit from Roger). I would appreciate any advise on the jobs at hand as this will be my first project on my car other than heater control valve replacement.
