1991 GT - Manual transmission wiring harness
1991 GT; When you put the car into rear gear the rear white lights are not working. Seem like the manual transmission wire harness from the hatch to the manual transmission is missing . Does any none know what it looks like or its part number,
Thanks,
Thanks,
Electron Wrangler
There are 2 wires from the reverse switch on the transmission to a 2 pin connector (T7) in the area above and in front of the battery box in the front most notch of the wheel well. The car side wires are Blue & Black/Blue.
The wiring should be attached to the transmission with boot and go via a grommet the connector end.
Alan
Alan
Archive Gatekeeper
Here's a pic of the reversing harness connector in the spare tire well:
