928 Forum 1978-1995
Sponsored by: 928 Specialists
Replacing green wire
Old Nov 13, 2014 | 04:50 AM
hopwood's Avatar
hopwood
Default Replacing green wire
Hi all,
Is there a way to replace the green wire without having to reset the timing on the distributor?
I just did the one in my track car, and want to do the one in my street car, but would rather not disturb the dissy timing if I can.
Joel
Old Nov 13, 2014 | 07:09 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
use a marking pen draw a line from the housing to the dist housing then turn the dist housing
if you do this at TDC then the rotor should still line up at the hash mark
Old Nov 13, 2014 | 09:21 AM
jwillman's Avatar
jwillman
I did mine a month ago and was able to leave the distributor in place an get to the green wire hold down plate screws using an off set screw driver.
