Oil scraper piston ring
I'm currently putting back my engine together and when I inserted the last piston in the block I managed to damage the oil scraper ring
. I'm planning on replacing the scraper ring on this piston only. Should I be concerned by replacing only this one? Or should I replace all scraper ring so they are all the same?
The scraper ring cannot be saved. It slipped out of the ring compressor and when I pushed the piston in, one end of the lower ring folded up and got nicked by the spacer between both ring. It also scratched the cylinder a bit but above the compression ring line.
