928 Forum 1978-1995
Sponsored by: 928 Specialists
No top end
Old Aug 16, 2003 | 07:51 PM
reno928s's Avatar
reno928s
Default No top end
I was trying to accelerate past 100 mph but the car seemed to struggle and sputter, no significant power at top end. I already changed the fuel pump and the problem is still there. Any ideas? Thanks, Reno Also it's a 1984 928S Euro 310 Hp.
Old Aug 16, 2003 | 08:00 PM
Steve J.'s Avatar
Steve J.
Maybe the engine can't breathe. Clogged air filter or cats? How about distributors or plug wires? Fuel + air + spark...
Old Aug 16, 2003 | 08:20 PM
reno928s's Avatar
reno928s
I changed the fuel filter, fuel pump, wires, plugs, fuel reg(2), Fuel dampner, MAF, temp II sensor. I know I need a clutch can that be the cause? Thanks, Reno
Old Aug 16, 2003 | 08:41 PM
Steve Cattaneo's Avatar
Steve Cattaneo
If you can drive your car from a dead stop in 3rd or 4th gear without stalling, the clutch is slipping. If it is slipping that could be the problem
Old Aug 17, 2003 | 12:01 AM
figgen's Avatar
figgen
If the clutch was slipping wouldn't the car still rev to red line but not transfer the power to the wheels??
What gear were you in when you went for the rip? RPM ??
BTW I have the same issue but haven't had time to trouble shoot with my T-belt alignment issue still lurking. My first plan is to test the CAT's for plugging.
Old Aug 17, 2003 | 12:13 AM
User 4221's Avatar
User 4221
How about vacuum advance on the distributors? spark coil? dreaded green wire? Timing?
If it were the clutch, the engine would continue to rev upward with little or no gain in speed.
It sure sounds like ignition to me
Old Aug 17, 2003 | 06:03 AM
John Speake's Avatar
John Speake
Hi Reno,
Is the car a Euro LH equipped (twin distributors, or the K-jet (single distributor, mechanical injection) ?
Has trhe car been modified in any way to pass US emissions ?
Did the "low power" develop quickly or slowly ?
Old Aug 17, 2003 | 12:12 PM
reno928s's Avatar
reno928s
LH Equipped, Reno
Old Aug 17, 2003 | 12:38 PM
John Speake
Has the car been modified in any way to pass US emissions ?
Old Aug 18, 2003 | 01:28 AM
reno928s's Avatar
reno928s
Sorry for posting late, Scott c-Cannot adjust timing, my car has the dual distributors and I changed both coils. Steve C-I was able to start from a dead stop in fourth gear without stalling. When I did my run of 100mph I was in fifth gear. John Speake-My car is the twin distributors and LH equipped. My car was modified for US delivery. One other thing, sometimes not all the time, if i floor it in first or second gear the car feels like it has turbo lag or a late power surge. Thanks for all the replies, Reno.
Old Aug 18, 2003 | 08:37 AM
John Speake
Hi Reno,
What you describe sounds like weak mixture.
Has it been eqippped with cats and an O2 loop ?
Old Aug 18, 2003 | 12:16 PM
reno928s's Avatar
reno928s
John, Yes I Do Have cats. This weekend I had my car at my mechanic, where he performed a diagnostic of the exhaust gas. Originally I had failed for NOx, Standard reading is 1146 and my car's result was 1347. My mechanic told me it's fine. What causes a weak mixture? Thanks, Reno
Old Aug 18, 2003 | 01:57 PM
John Speake
Hi Reno,
There never was a factory version of the LH 16v with cats and a full O2 loop. Does your car have an O2 sensor, and loop back to the ECU ?
On an "open loop" Euro S2, the classic weak mixture problem is the MAF. You said you have changed it - was it a new exchange unit ?
If you car has some sort of closed loop O2 system, it must be a strange installation............as I said, there was never a factory O2 kit for the LH 16v.
There was of course for the early US 32v. but that system probably wouldn't work well with a 16v 4.7l
Old Aug 19, 2003 | 02:37 AM
reno928s's Avatar
reno928s
John, My X-mechanic charged me 870.00 for the MAF, it better be new. I failed inspection here are my readings CO%-Standard-0.86 My results-0.00 HC-Standard-152 My results 13 NOx-Standard-1146 My results-1347 With the above readings, can this be the source of my problems? I also have the computer serial # if it helps 928 618 123 00. Should I eliminate the cats? Thanks, Reno
Old Aug 19, 2003 | 02:22 PM
John Speake
Hi Reno,
Both your CO and HC very low readings suggest a very weak mixture, even taking into account the airpump. The NOx can be high if mixture too weak or too rich. Need to be near lambda =1 for lowest NOx.
Ask you garage to disconnect the air pump and asdjust the MAF for a CO reading of 1%. The set the idle speed to 700rpm.
Connect up the pump and try the emissions test again.
If the MAF won't adjust to 1% then it's faulty, or the car has another fault (air leak etc)
I assume your car has cats but no O2 loop, as the LH ECU number you quote is correct for a S2 Euro.
hope this helps.
