Intake is out, valley cleaned...
- knock sensor plastic has crumbled
- Hall sensor connector (male) crumbled
- TPS connector seems fine, but has seen better days--no crumbling/breakage, but just looks old.
- TPS looks old.
- ISV connector is fine.
- CPS is currently soaked with PB Blaster.
- I'm pretty sure the two right-side breather hoses are fine.
- I'm pretty sure the long 3-way hose is fine.
- I'm pretty sure the left throttle-to-brake venturi is fine.
- The two larger hoses attached to the ISV are rigid and were stuck to the nipples--had to split one with a blade.
- The flappy actuator does not look 23 years old--the whole area around that actuator is very clean. I'm going to try to test it. I might need to get a Mityvac, or the like.
- All soft fuel lines are out for replacement.
- All dampers and regulator are out for replacement--two had fuel in the vacuum chamber.
- Some of the small vacuum line elbows have seen better days; will probably just get the whole $65 VC kit from Roger.
I learned two things I haven't seen mentioned elsewhere:
- remove the intake side plates after the fuel rails are out, and you have easy access to all intake-to-engine nuts;
- replace the round, 6mm hex bolts that secure the damper brackets after removing the brackets. Those bolts help seal some type of coolant ports--still not sure what they are, but I had a valley full of water from two days without those bolts being replaced.
I also found it handy to leave the injectors in until after the intake was out.
Also, I thought I was going to be fine paint-wise because my intake looked so good--no flaking was visible. Now it is clear that nearly all of the paint is simply floating above the surface of the intake waiting to flake, which it now has. It's got me thinking about powder-coating.
I'll have pics tomorrow. It got too dark tonight.
Louis
Well if applicable, I'm familiar with the S3 innards....
Recommend Check the main vac line back to the trans to ensure it is holding.
While Far afield of intake R&R and vac work, but the heater valve and hoses are right there.....
Louis
Paint tip: when U have removed the side panels, feel the sharpness of the outer edge on the manifold body. This sharp edge is a stress raiser and is where the paint begins to fail as it heats and cools, so smooth it off a little before doing anything paint or coating wise.
I repainted my S4 manifold 12 years ago (used an automotive acrylic) and it's still happily in place today.
Cheers & HTH.
Good point on the vac line to the tranny. I'll probably have Roger throw that one in too. The elbow at the modulator didn't look great.
You're right, the water bridge, heater and radiator hoses, and thermostat are all right there. I am replacing the two sensor/switch things on top of the water bridge. The coolant hoses look and feel good--I'm sure they've been replaced at some point. For that matter, at least one of the breather hoses around the intake had an Oct/2005 date on it. So, someone has been in there before, and the car seems well taken care of. The fuel lines have been changed before also. I get the feeling that a significant amount of R&R went on about 9-10 years ago.
Cheers & HTH.
I am seriously considering painting it myself. I'll have to see what I feel like after trying to get some of the old finish off. What did you round off the edge with--fine file, sanding block?
Thanks all,
Louis
Pics to come.
I know that edge. I've got a nice clean cut across one of my knuckles from it.
Thanks all,
Louis
Pics to come.
Mike
Mike
ALWAYS! ALWAYS! ALWAYS! Turn over at least TWICE by hand before attempting starting. This is engines 101. Besides the coolant, you can never be 100% sure nothing fell into the cylinder. Turning by hand , while only 99 44/100 ths sure, is the best way to prove it. Personally I turn it five or six times from paranoia.
Mike
I didn't see any evidence of water in the 4 and 8 ports, but I couldn't be sure some hadn't made it past the valves. I need to check the plugs anyway, I guess. How much turning of the engine will make sure the water is out? Should I pour a little gasoline in 4 and 8 to help clear the water?
I need to change the oil too. Maybe I should change it twice--once after throwing any water out, before any starting, and a second time after the engine runs for a few minutes to get warm. Any suggestions here?
Thanks,
Louis
Does cranking with the plugs out and fuel pump fuse removed count as "by hand?"
