Par number: 928.613.068.00?
I found this small wiring harness in the passenger side door pocket. It's got a green connector on one end and a black...thing...on the other. I've attached a pic. I'm curious what it is, if anyone knows...
Old and used up window switch.
Thanks Sean. I can toss it...I remember Brian replaced a bad one before I bought the car so I guess I don't need to keep that.
Cut off the switch end and you can re-use the wires/connectors for other projects. The wire is of really good quality.
That's a good idea actually, assuming I don't stash it somewhere and then completely forget about it.
