Fuel Lines metric to AN6 adapter size
I am thinking of converting to a single adjustable FPR in the rear and using flexible ss fuel lines and AN6 fittings. A thorough search showed lots of conversions to single FPRs from a few folks such as Duckman82, jorj7 to name a few.
What is the size of the metric AN6 adapter needed to connect to the Porsche fittings? There are so many variations made by Russel (AN6 to 10mm X1, or to 12, 14, 16, 18 etc X 1.0 or 1.5).
Please and thanks
Please and thanks
Fred,
For the latest iteration of my fuel system I used a 16mm x 1.5 to -6 AN adapter (if I remember correctly) for the fuel rail to -6 AN hose. For the fuel pressure regulator to -6 AN hose I used one of Greg Brown's metric hose ends. This set up allowed me to use the stock fuel pressure regulator and still get the MAF to fit properly. When I was using an aftermarket fuel pressure regulator I used two metric/AN adapters and mounted the regulator on the driver's side firewall.
Adapter
Measuring the adapter outer diameter
Home made fuel line with adapter
Fuel line installed
Prior fuel pressure regulator
Hope this helps.
George
90 S4 Grand Prix White (Murf #5)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
Adapter
Fuel line installed
Hope this helps.
George
Here is a photo of the prior, prior set up...
Aeromotive instead of the Weldon fuel pressure regulator.
George
George
Thank you George & The FO.
I will be using an Aeromotive FPR and also make some home made lines to fit.
I will also eliminate the two dampeners as others have shown the system works fine without them
Fred
Fred
I would argue the system DOES work without them. It runs, right?
But plot the results in A/F over a # of hours driving, and you'll find issues not having them.
Update: Just helped a friend resolve an odd drivability issue.
Was the damper..it was bad.
You need a damper.
You need a damper.
