An 87 CE Panel Refresh Picture Thread from a Second-Timer
After buying a couple of cans of DeoxIT spray, I thought I would refresh the CE panel on my '87 928S4.
It is a very simple, but time-consuming, job.
First, unscrew two thumb screws on the the tool tray in the back hatch.
![Name: 140928 01 Open Tool Tray.jpg
Size: 25.4 KB](https://rennlist.com/forums/attachments/928-forum/873258d1411945086-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-01-open-tool-tray.jpg)
Next, remove the wing nut that connects the battery ground-strap to the chassis.
![Name: 140928 02 Wingnut.jpg
Size: 40.5 KB](https://rennlist.com/forums/attachments/928-forum/873259d1411945086-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-02-wingnut.jpg)
The '87 has a cargo net. I use it to hold the ground strap away from anything that could ground the electrical system.
![Name: 140928 03 Ground Strap.jpg
Size: 43.0 KB](https://rennlist.com/forums/attachments/928-forum/873260d1411945086-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-03-ground-strap.jpg)
Next, there are two (one on each side) 8mm nuts that hold the parcel tray in the passenger footwell. Remove both.
![Name: 140928 03a Package Tray.jpg
Size: 53.5 KB](https://rennlist.com/forums/attachments/928-forum/873261d1411945086-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-03a-package-tray.jpg)
The bulb control module is attached to the package tray.
![Name: 140928 04 Bulb Control Module.jpg
Size: 30.1 KB](https://rennlist.com/forums/attachments/928-forum/873262d1411945086-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-04-bulb-control-module.jpg)
Better to disconnect it, to have more room. I used a flathead screwdriver and gently pried the female end of the connector from the male end of the module.
![Name: 140928 05 Bulb Control Module 2.jpg
Size: 27.1 KB](https://rennlist.com/forums/attachments/928-forum/873273d1411945500-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-05-bulb-control-module-2.jpg)
This is the Central Electric (CE) Panel.
![Name: 140928 06 CE Panel.jpg
Size: 53.2 KB](https://rennlist.com/forums/attachments/928-forum/873274d1411945500-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-06-ce-panel.jpg)
This is the lower wooden cover for the CE panel.
![Name: 140928 07 Lower Cover.jpg
Size: 53.8 KB](https://rennlist.com/forums/attachments/928-forum/873275d1411945500-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-07-lower-cover.jpg)
It has two 10mm nuts. Put them in a safe place, along with the washers, and remove.
![Name: 140928 08 Lower Cover 2.jpg
Size: 38.8 KB](https://rennlist.com/forums/attachments/928-forum/873276d1411945500-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-08-lower-cover-2.jpg)
The upper wooden cover for the CE panel swivels. There are two 10 mm bolts (one on the left, one on the right) that need to be removed.
![Name: IMG_3372.JPG
Size: 42.7 KB](https://rennlist.com/forums/attachments/928-forum/873277d1411945500-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-img_3372.jpg)
The top of the CE panel has two Phillips head screws that hold it in place. (Mine was missing one.) Remove the two screws.
![Name: 140928 09 Phillips Head.jpg
Size: 35.6 KB](https://rennlist.com/forums/attachments/928-forum/873288d1411945826-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-09-phillips-head.jpg)
The power to the CE panel is at the top. Remove the translucent plastic cover that protects the positive terminals by pinching them at the sides of the plastic.
![Name: 140928 10 Positive Terminal Cover.jpg
Size: 40.6 KB](https://rennlist.com/forums/attachments/928-forum/873289d1411945826-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-10-positive-terminal-cover.jpg)
Using a 10mm wrench, unscrew both power wires (in red insulation.)
![Name: 140928 11 Positive Terminal.jpg
Size: 34.4 KB](https://rennlist.com/forums/attachments/928-forum/873290d1411945826-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-11-positive-terminal.jpg)
After freeing the power wires, I put the 10mm nuts back onto the top of the CE panel, so as not to lose them.
![Name: 140928 12 Positive Terminal.jpg
Size: 36.7 KB](https://rennlist.com/forums/attachments/928-forum/873291d1411945826-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-12-positive-terminal.jpg)
I labeled the wires "left" and "right."
![Name: 140928 13 Power Wires.jpg
Size: 20.5 KB](https://rennlist.com/forums/attachments/928-forum/873292d1411945826-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-13-power-wires.jpg)
At the bottom of the CE panel, there is a red tab that is pushed down and pulled out. This frees the colored connectors from the CE panel.
![Name: 140928 14 Multi-Pin Connector Release.jpg
Size: 34.7 KB](https://rennlist.com/forums/attachments/928-forum/873294d1411946142-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-14-multi-pin-connector-release.jpg)
Gently lift the tab on each connector, then gently pull the connector out. Repeat.
![Name: 140928 15 MultiPin Connector.jpg
Size: 33.3 KB](https://rennlist.com/forums/attachments/928-forum/873295d1411946142-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-15-multipin-connector.jpg)
When you are done, the CE panel looks even more chaotic than before.
![Name: 140928 16 CE Panel.jpg
Size: 61.7 KB](https://rennlist.com/forums/attachments/928-forum/873296d1411946142-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-16-ce-panel.jpg)
Disconnect the ground wires from the left ground point, above the CE panel. 10mm socket.
![Name: 140928 33 Ground Point.jpg
Size: 26.5 KB](https://rennlist.com/forums/attachments/928-forum/873309d1411946313-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-33-ground-point.jpg)
Now you are ready to remove the CE panel from the passenger footwell. I put the CE panel- to the delight of my wife- on the kitchen table.
![Name: 140928 17 CE Panel.jpg
Size: 45.6 KB](https://rennlist.com/forums/attachments/928-forum/873297d1411946142-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-17-ce-panel.jpg)
The back of the CE panel looks like grey spaghetti.
![Name: 140928 18 CE Panel Back.jpg
Size: 55.9 KB](https://rennlist.com/forums/attachments/928-forum/873298d1411946142-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-18-ce-panel-back.jpg)
I removed all of the fuses.
![Name: 140928 19 Fuses.jpg
Size: 16.6 KB](https://rennlist.com/forums/attachments/928-forum/873299d1411946165-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-19-fuses.jpg)
![Name: 140928 20 Fuses.jpg
Size: 23.0 KB](https://rennlist.com/forums/attachments/928-forum/873300d1411946165-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-20-fuses.jpg)
Then, I removed all of the relays.
![Name: 140928 21 Fuses and Relays.jpg
Size: 41.2 KB](https://rennlist.com/forums/attachments/928-forum/873301d1411946165-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-21-fuses-and-relays.jpg)
Taking the CE panel outside, I sprayed a short burst of DeoxIT onto every electrical connection in the CE panel. I waited 10 minutes, and then did it again.
![Name: 140928 22 DeoxIT.jpg
Size: 35.5 KB](https://rennlist.com/forums/attachments/928-forum/873302d1411946165-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-22-deoxit.jpg)
Next, I diluted one part Stabilant-22
![Name: 140928 24 Stabilant 22.jpg
Size: 25.7 KB](https://rennlist.com/forums/attachments/928-forum/873304d1411946191-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-24-stabilant-22.jpg)
...with four parts Isopropyl Alcohol...
![Name: 140928 23 Alcohol.jpg
Size: 30.8 KB](https://rennlist.com/forums/attachments/928-forum/873303d1411946165-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-23-alcohol.jpg)
And after gently cleaning each surface of every fuse and relay terminal with a dremel wire brush, painted the diluted Stabilant-22 onto each terminal.
![Name: 140928 25 Fuse.jpg
Size: 37.1 KB](https://rennlist.com/forums/attachments/928-forum/873305d1411946191-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-25-fuse.jpg)
![Name: 140928 26 Fuse 2.jpg
Size: 35.4 KB](https://rennlist.com/forums/attachments/928-forum/873306d1411946191-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-26-fuse-2.jpg)
I also painted each terminal on the CE panel with the diluted Stabilant-22.
Then, I put each fuse and relay back into the CE panel.
Now, time to return the CE panel to the passenger footwell. There are two plastic nubs at the bottom of the CE panel (the one pictured below is between "R" and "S." The nub should sit in an appropriately-sized indentation in which it fits. Make sure it is seated properly.
![Name: 140928 27 CE Panel Nub.jpg
Size: 38.7 KB](https://rennlist.com/forums/attachments/928-forum/873307d1411946191-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-27-ce-panel-nub.jpg)
The power wires need to be draped over the CE panel before screwing it back in place.
![Name: 140928 28 Power Wires.jpg
Size: 35.4 KB](https://rennlist.com/forums/attachments/928-forum/873310d1411946798-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-28-power-wires.jpg)
The ground wires do, as well.
![Name: 140928 29 Ground Wires.jpg
Size: 25.6 KB](https://rennlist.com/forums/attachments/928-forum/873311d1411946798-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-29-ground-wires.jpg)
Secure the power wires onto the top of the CE panel. 10mm.
![Name: 140928 34 Power Wires.jpg
Size: 58.2 KB](https://rennlist.com/forums/attachments/928-forum/873315d1411946835-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-34-power-wires.jpg)
![Name: 140928 30 Power Wires.jpg
Size: 51.7 KB](https://rennlist.com/forums/attachments/928-forum/873312d1411946798-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-30-power-wires.jpg)
(Also, secure the ground wires to the left ground point- MP V)
Secure the CE panel to the floor with a Phillips screwdriver.
![Name: 140928 32 Phillips Head.jpg
Size: 47.1 KB](https://rennlist.com/forums/attachments/928-forum/873313d1411946798-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-32-phillips-head.jpg)
Restore the translucent positive terminal cover.
![Name: 140928 35 Positive Terminal Cover.jpg
Size: 65.1 KB](https://rennlist.com/forums/attachments/928-forum/873314d1411946798-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-35-positive-terminal-cover.jpg)
The lower wooden cover goes on, with washers. Two 10mm nuts.
![Name: 140928 37 Lower Cover 2.jpg
Size: 26.5 KB](https://rennlist.com/forums/attachments/928-forum/873317d1411946835-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-37-lower-cover-2.jpg)
![Name: 140928 36 Lower Cover.jpg
Size: 61.5 KB](https://rennlist.com/forums/attachments/928-forum/873316d1411946835-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-36-lower-cover.jpg)
The upper wooden cover (the one that swivels) goes back on- two 10 mm bolts.
![Name: 140928 38 CE Panel Cover.jpg
Size: 21.6 KB](https://rennlist.com/forums/attachments/928-forum/873318d1411946835-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-38-ce-panel-cover.jpg)
Almost done.
![Name: 140928 39 Almost Done.jpg
Size: 38.7 KB](https://rennlist.com/forums/attachments/928-forum/873319d1411946835-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-39-almost-done.jpg)
Restore the package tray, secure the two 8mm nuts.
Reattach the bulb control module.
![Name: 140928 40 Bulb Control Module.jpg
Size: 30.4 KB](https://rennlist.com/forums/attachments/928-forum/873320d1411946842-an-87-ce-panel-refresh-picture-thread-from-a-second-timer-140928-40-bulb-control-module.jpg)
Reattach the ground strap to the chassis via the wing nut at the back of the trunk, restore the tool tray, and you are good to go.
Almost done.
Nice writeup. I used the one on Sharkskin's page and it was also easy to follow.
I made sure that I labelled all of the letter coded plugs. It was when I was plugging them back in that I noticed that each plug already had the proper letter molded into the plastic.
You might want to invest in a simple workbench. Wives will only tolerate so much.
Nice write up. Thans for doing this. Did you notice a difference after the treatment?
Electron Wrangler
Its good to see a good photo write up on the later panels to go along with Dave's for the early panels.
The two power wires to the top of the panel both go to the jump post - you can fit them in either location - just whatever reaches best - makes no difference.
Be careful with the top retaining clips for the plugs - they are very brittle - if you stress them too far upwards they will snap off. Best way to remove the plugs is to make a puller tool - a paperclip works. The plug bodies have 2 diagonally opposed tabs that stick up with a small hole in each. Open up the paperclip, bend the paperclip into a U shape, then bend a small hook into each open end with pliers. Pop the hooks though the tabs and then you can pull the plugs out straight from the panel with one hand while easing the retainng tab with a flat blade. Don't pull on the wires.
The plugs & panel have a coding scheme built in to ensure that you cannot install a correctly colored plug in the wrong socket - it can't be done, everything is already labelled - so just match colors.
Alan
Alan
