928 Forum 1978-1995
Sponsored by: 928 Specialists
Pod Removal/Bulb refresh
Old Sep 7, 2014 | 01:39 PM
marine928's Avatar
marine928
Veteran: Marine Corps
Default Pod Removal/Bulb refresh
Getting ready to replace all the bulbs in the instrument cluster with led's and will doxit everything at the same time.
Printed out Schocki's 15 min. procedure and Dwayne's as well. Noticed that Mr. Ball indicated that he could not remove the pod per the 15 min procedure. Since I have an 87 which procedure will I be able to use?
Also, any suggestions from experienced pod removers is greatly appreciated.
Thanks,
Lon
Old Sep 7, 2014 | 02:59 PM
syoo8's Avatar
syoo8
Hi Lon,
Pod removal takes me 5 minutes. The first time I did it, it took an hour. The pod removal is the same (more or less) for the 928. Use Dwayne's and keep track of which bolts, screws, etc. go where. It is very simple.
The hardest part (in my opinion) is putting it back together. Good luck!
Old Sep 7, 2014 | 04:21 PM
NoVector's Avatar
NoVector
Definetly check out Ed's guide:
http://www.ed.scherer.name/porsche_9...0to%20LEDs.pdf
His LED dimmer has been great too: https://rennlist.com/forums/928-foru...g-to-leds.html
Old Sep 7, 2014 | 04:26 PM
marine928's Avatar
marine928
Scott thanks for the info. Did you have to remove the steering wheel, Dwayne's write up has him doing that. Also No Vec, I purchased Ed's dimmer a couple of months ago, glad you reminded me, I had forgotten that I even had it....
Old Sep 7, 2014 | 08:58 PM
syoo8's Avatar
syoo8
Yes, you have to remove the steering wheel, remove the turn stalk mechanism, remove some of the plastic trim pieces (do not over tighten when you reinstall).
By the way, remove the ground strap before you do all of this. Good luck!
Old Sep 8, 2014 | 04:36 AM
yaskota's Avatar
yaskota
Watching closely as I've put off my Pod refresh until I could put in LEDs too. Mine's an '84 though so I'm not sure mine will look as nice as those with later digi-dashes though.
Best wishes on your changeover & refresh Lon!!!
-tom
Old Sep 8, 2014 | 10:01 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I added Deoxit to the rheostat and the pod connections the stock lights are plenty bright enough now
Old Sep 8, 2014 | 10:26 AM
marine928's Avatar
marine928
Mrmerlin. I deoxed my entire fuse panel, relay switches and every other connection I could get to ( head/tail lights also engine compartment connections) last month. As a result my pod lights look much brighter as well. I decided to make the led changeover as part of my preventive maintenance schedule.
I am going to replace my odo gear before it goes bad. I just turned 112000 miles and according to everything thing I read, the gear is on borrowed time.
With that being said, this will be a good time to upgrade to led's and to deox the entire instrument cluster and pod connections.
Being proactive keeps our exotic cars on the road.
Thanks for everyone's input.
Lon
Marine928
added, my rheostat is also acting up as well.
Old Sep 8, 2014 | 10:46 AM
marine928's Avatar
marine928
Tom, I have the old school instrument panel also in my 87. I prefer it over the electronic hands down.
-tom
Old Sep 8, 2014 | 11:03 AM
marine928's Avatar
marine928
Syoo8, 5 minutes huh, ....
Old Sep 8, 2014 | 11:15 AM
Calgary Ole's Avatar
Calgary Ole
Because you do not have an airbag car, remove the steering wheel first! Like others have said keep track of where everything belongs. There are short and long bolts and brackets with clips that may fall out when loose. Getting it all back together was the tricky part the first time I did this job. Dwaynes write-up has a tip about some tape on the 'spacers' for the right side of the pod where the cluster attaches and rotates to the left side. It worked quite well for me.
Also, be careful with the clips on the back of the cluster. They have tabs that go inward which releases the clip and outward when installing sucks in the clip if I recall correctly.
Old Sep 8, 2014 | 11:41 AM
marine928's Avatar
marine928
Thanks Calgary, I will be sure and take pics of everything before removing it and label them too. I hate having 1 or 2 bolts or nuts left over. Kinda like missing socks in the dryer, you wonder where the heck they went ��
