928 Forum 1978-1995
Sponsored by: 928 Specialists
İnjector replacement
Old 09-06-2014, 03:27 PM
LFA
LFA's Avatar
Default İnjector replacement
My 1987 S4's engine is being rebuilt. 2 of the injectors are not working. What are my options 2 or 8 new/used injectors, bosch/ aftermarket. Thanks
Old 09-06-2014, 03:33 PM
Leon Speed
Leon Speed's Avatar
Get 8 new fuel flow matched 19lb injectors from fiveomotorsports. Roger at 928sRus carries them as well I think.
Old 09-06-2014, 03:40 PM
LFA
LFA's Avatar
İs it risky to buy just 2 and replace the faulty ones?
Old 09-06-2014, 03:44 PM
Leon Speed
Leon Speed's Avatar
Honestly I don't know. I guess it shouldn't be a problem if the injectors have the same flow rate. Maybe you could send all 8 injectors out to get tested and reconditioned. I just nknow some places inthe US and in Germany but there must be some in Turkey.
Old 09-06-2014, 03:58 PM
LFA
LFA's Avatar
I have already done that, they have been cleaned in an ultrasonic cleaner and tested at different rpms, leak test, etc and the result shows, 6ok, 2needs replacement
Old 09-06-2014, 04:28 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
I wouldn't mix and match- besides the flow rates possibly being different, the impedances might be a little different, or the opening times, or whatever. Too many possible uncontrollable variables.
See the discussion in post #8, here, for more detail:
https://rennlist.com/forums/928-foru...s-in-a-s4.html
It is way easier to just pick up a set of modern 4-hole 19 lb injectors from Roger or FiveOmotorsports, for not much more than the price of having the old ones cleaned and flow matched.
Looks like the two possible Design II Bosch 19 lb injectors that have the proper injector clip slots and look somewhat like stock 19 pounders are:
0 280 150 556
and
0 280 150 943
Old 09-06-2014, 04:40 PM
LFA
LFA's Avatar
0 280 150 556
and
0 280 150 943
Thanks,
I will speak with Roger on Monday
Can I also use these 2 bosch injectors you mentioned, or they have not been tested on 928 yet?
Old 09-06-2014, 04:54 PM
Rob Edwards
Archive Gatekeeper
The 556 or 943s will work fine on a stock 5L S4. I would buy them from Roger as he will be sure to include the proper diameter lower O-ring so you get proper sealing in the opening in the intake manifold.
Old 09-06-2014, 04:59 PM
LFA
LFA's Avatar
Thanks, very much appreciate yoır help
Old 09-06-2014, 06:32 PM
alabbasi
alabbasi's Avatar
Send them to me and I'll clean them for a nominal fee
I'll even replace the filters, pintle caps and o-rings.
Old 09-06-2014, 07:09 PM
MjRocket
MjRocket's Avatar
Does that offer stand for anyone else?
Old 09-06-2014, 09:37 PM
LFA
LFA's Avatar
Thanks, they have already been cleaned and tested on a similar equipment like yours but 2 of them turned out unrepairable due to sitting idle for a long time. Thanks for the offer anyway
Old 09-09-2014, 12:14 PM
danglerb
danglerb's Avatar
When I sent injectors out for cleaning I sent a few extra so the cleaning/testing guy can put together a matched set. Good that I did as same as you a couple were bad/too far off.
Old 09-09-2014, 04:41 PM
soontobered84
soontobered84's Avatar
Alabbasi,
I have the Stepson apart and would love to have the injectors cleaned, flowtested etc. What is your nominal fee and how can I get them to you?
MjRocket
MjRocket's Avatar
Originally Posted by soontobered84
Alabbasi,
+1
Quick Reply: İnjector replacement
