Gauge warning lights
On my 82 5 speed, the gauge warning lights for the voltmeter, coolant temp and oil pressure gauge are inop. Fuel gauge light does work as do the gauges.
I know a failed voltmeter light can cause the alternator not to excite at low rpms and I have grounded the #1 pin in the 14 pin connector to see if the light comes on. It does not, so I am assuming the light is burnt out.
Other than being a nuisance, do the coolant and oil pressure warning light being inop cause any ancillary problems?
I guess I could get lucky and cleaning all connections in the pod will fix the problem.
Other than a failed bulb, is there any other reason these warning lights aren't working?
I plan on dropping the pod when it cools down outside to address the voltmeter inaccurate readings and alternator excitation problem. But I understand these warning bulbs are quite pricey.
Anyone know the part numbers for these warning light bulb assemblies? Thanks.
Luckily I have an aircraft electrician expert that can fix about anything with electrons and all the diagnostic equipment that is necessary.
I was thinking the foil board might have some breaks. I have read that guys have fixed theirs with careful solder flowing across the leads.
I guess we test everything once I pull the pod and it gets much cooler in Houston.
I've tried a few fixed and with solder and thin wire, but it's only a temp fix. We know Porsche Classic will charge $500.00 each if they reproduce it.
I am sure he would be interested in a little sideline work.
I will let you know after I pull the pod and completely go through all the circuits how bad of shape mine is in. But since it is only a nuisance right now, it will be a least a month before I pull the pod.
He would have to guesstimate how much his time would be worth, but I will keep you informed.
I did a hard wire conversion - replaced the foil with wires and terminal boards and used molex connectors. Has worked great and cost about $30 in materials and a few hours time. Did a second one for another local rennlister and it went faster as the design work was already done
Hardest part is developing the plan and wire schematic.
