Check valve at fuel pump
My 83 M28/11 with CIS injection is fuel starved at start up after it sits for 3 to 4 hours. I had a new fuel pump put on after the engine swap from the 84 M28/20 to a high pressure pump and it came with a new check valve, but I would still like to change the valve to be able to rule it out as the cause. I already have the valve and I am wondering if there are any tricks to replacing it. How much fuel will I encounter when I take the old one off and is there a way to relieve pressure before I loosen the connectors? If my theory is correct there will be no pressure anyway, but my theories have a way of not always being correct.
Joe
Joe
Basic Sponsor
Have you checked your accumulator for leaks? The accumulator holds pressure for restarts.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Roger,
I had an 84 with electronic injection and when I switched to the 83 with CIS, it wanted an in tank auxiliary pump and an accumulator. You talked me out of them because they were not necessary. I still believe that to be true. A ll I want to do is replace the check valve or restrictor valve to see if it is my start up problem and I need to know how much gas I might encounter when I remove the valve..
Thanks for taking the time to help me out on this,
Joe
Joe
