Yellow S4 5spd in Pheonix
http://phoenix.craigslist.org/evl/cto/4567306819.html
Beautiful looking car. I don't think I've ever seen this yellow on a non-gts. Must have been a color change when they removed the rubstrips? Very nice.
No hot post cover. Someone had to say it...
Yep, jump post cover is gone but the cap is there. Bad bad bad.
I was referring to the cover for 14 pin con. Geesh.
Back to the car... nice options on it. One day I would like to try a manual with the lsd.
Electron Wrangler
Interesting that the fuel rail covers are painted to match the intake - not sure I've seen that before..?
The inside sensor port is presumably damaged underneath that - it will certainly prevent the climate control closed loop mode from working very well
Seats look to have been worked on some - not really bad but a bit different looking (stuffing, cover install).
I think generally it looks pretty good - and these things are pretty easy to fix. In Phoenix lack of a hot post cover is unlikely to make much difference to the 14 pin connecctor condition, (obviously there are other reasons to have one).
Even if the air pump is gone an airpump filter cover would be nice... they rarely look for emissions equipment here - but this is a bit of a red flag.
Alan
Alan
