928 Forum 1978-1995
Sponsored by: 928 Specialists
help finding a thread on electrical grounds
Old Aug 4, 2014 | 03:36 AM
Richards 928's Avatar
Richards 928
Default help finding a thread on electrical grounds
Hi All,
Some time ago I came across a thread that had pictures and descriptions of 15-20 ground locations that require periodic maintenance with contact cleaner and dialectic grease. It was an excellent post and I made a note to come back to it when I had some time to do the work described in it.
I was ready to start tonight and was looking for the thread, using the site search I could not locate it. If anyone knows the thread could you help identify it?
thx
Richard
Old Aug 4, 2014 | 05:37 AM
Ranfurly's Avatar
Ranfurly
Look in the new owner FAQ thread page 3, post 33 by Randy V has a diagram.
Richard
Old Aug 4, 2014 | 11:25 AM
9two8's Avatar
9two8
This post any good.....,
https://rennlist.com/forums/928-foru...y-grounds.html
Ken
80 928 S
5 Speed
UK
Old Aug 4, 2014 | 11:41 AM
MainePorsche's Avatar
MainePorsche
And, don't forget the engine ground under the car. It is a large braided uninsulated cable from the block to the chasis on the passenger side in the lower bellhousing region.
Add: Also not pictured is MP I under the headlight torsion bar in front of the headlight motor. MP X is a black thick wire from the L side coil bracket to the front of the engine block. There are two MP's on the R front in the region of the hot post - one under and behind it, and the other a little forward of the post tucked in along the fender wall. And don't forget the strap off the battery NEG to the L of the hatch motor on the floor of the hatch - remove tool tray for this.
