fuel line blew up !
Hello today I started my 928 and I smelled a lot of gas fumes stepped out of car and noticed a paddle of gas . Took apart intake and noticed the hose was leaking from being all cracked up . Can I buy this part anywhere ?
Been there. That's a sh&&TY/Dangerous situation.
Please order ALL fuel lines. Your car looks to be an 86 or older, so those fuel lines are more than likely...TOAST!
Archive Gatekeeper
Don't bother with scratchy lotteries for a while, you've used up all your good luck. +1 on Roger for a complete set of replacement fuel lines-
928 110 269 01 - front crossover hose
928 110 367 14 - fuel supply hose
928 110 271 00 - rear crossover hose
999 181 152 50 - fuel return hose.
Makes me glad that my car is at Greg's now, having a few things done, including replacing all fuel lines. It's not expensive compared to most 928 repairs, but buys a lot of peace of mind and avoids a potentially very nasty incident.
Please do replace all the fuel lines, for your own safety and the car's!
Wow I did think about all the electrical components that the gas went on and I was kind of freaking out , the car was running too when it was leaking . Just thinking about it again gives me goose bumps. It could have been a toast 928. Thanks for help I will call Roger on Mon .
Captain Obvious
Super User
Super User
Those cracks on that U shaped hose are not what caused the leak. Cut the line in half. There is a hard plastic line covered by the rubber. The rubber is only there for abresion protection, not to hold the fuel pressure, the had plastic line does that. Have a good close look at where exactly the leak was coming from.
Received 1,295 Likes
Yes. Very lucky to say the least.
Change all fuel lines before driving it again.
This could have turned a lot worse!
https://rennlist.com/forums/928-foru...d-a-928-a.html
Yes I do have a fire extinguisher and it is the u shaped hose for sure as I saw it drip when it was still on car and I bent it more .but yes I will change all the fuel lines. It was dripping right on the ground wire that is attached to the block. Behind the mas sensor. This is a second time I was lucky with no fire . First was the on rail fuel pressure gauge and the oil drained out it and im glad I noticed it when it was still 1/3 full . So I took it off.
