928 Forum 1978-1995
Sponsored by: 928 Specialists
what does the hall sensor really do?
Old Aug 1, 2014 | 04:58 PM
John Speake's Avatar
John Speake
Yes, the ECU that Andy has in his car could be more dependant on the signal from the Hall sensor being present. I have heard of some modern cars not starting when they have a Hall sensor problem.
Old Aug 1, 2014 | 05:54 PM
andy-gts's Avatar
andy-gts
Yes, Mr Speake, I just got off the phone with the Link g4 extreme rep for the area and you are right !!
no start with link with faulty hall sensor….whew….I thought it didn't make sense …
Old Aug 1, 2014 | 06:18 PM
IcemanG17's Avatar
IcemanG17
the hall sensor is just a cam position sensor.....like others said the ECU uses its signal to determine ignition timing. Which is why when it fails the cars are flat at higher RPM, since they loose 6' across the board as a safety measure....vs knock sensors which are 3'
it is a PITA to change.....i did it on my S4 before..... I believe in Mark Andersons racer car had this failure and it cost him around 60whp up high.....
Old Aug 1, 2014 | 06:41 PM
Jerry Feather's Avatar
Jerry Feather
Originally Posted by andy-gts
just replaced it after months of erratic behavior culminating in a no start condition , now runs great….but after heavy search..I have yet to fully understand the role of this sensor…..seems to be more important than I thought and the ecu needs good info to work properly (more than retarding timing)
any thoughts???
I think the purpose of that is to couple with your GPS and tell you when you are in close proximity to the Sharks in Hell so you can stop by and take part.
OH! Wait a minute! I think the is the HELL SENSOR. My mistake
Old Aug 2, 2014 | 04:04 AM
OTR18WHEELER's Avatar
OTR18WHEELER
You can call me Otis
Originally Posted by GregBBRD
Andy...
Was on my cell phone texting my GF while sitting at a red light and didn't see the light changed to green and flipped off the truck driver behind me, then I saw that you were the original poster.
Hall sensor, on your engine, could easily have a "larger role" than on the Bosch injection.
Sorry.
FIFY
Old Aug 2, 2014 | 12:10 PM
andy-gts's Avatar
andy-gts
what is fify ?
Old Aug 2, 2014 | 01:53 PM
Richard S's Avatar
Richard S
what is fify ?
Fixed it for you.
