PET install question
Gregg,
It was some time ago when I did mine, but I've just checked, and I have it installed in a seperate part of my hard drive ("D") - so it must be possible to determine where it is located.
maybe your version is different to mine
John,
Thanks. I did that before as well. But I now no longer have two drives. I didn't try installing it again. Maybe I'm blowing hot air without trying it again.
Is the heat wave still in effect? I've been laughing somewhat at what is called hot. My last property could be 110 during the day and 90 F at night. ALL SUMMER! It was dreadful. So I sold it and was rewarded handsomely. Ok, I'll stop bragging and get under the car...
Hi Gregg,
"D" is just a partition of my main drive.............
Yes, hottest day on record here today, about 100deg F. We're just not used to it !
And you know how the British are obsessed with the weather, as it's completely unpredicable. Always a sure topic of conversation.......
I just re-installed mine, after putting Win2000 on the system - didnt work . It gave me a choice of drives to install on, and full or programs only. Works fine after reinstall. You MUST set screen res at 1280x1024 for the install, but after that you can run at lower settings , just cant see all the data.
jp 83S
jp 83S
