928 Forum 1978-1995
Sponsored by: 928 Specialists
Cracked cylinder wall on cambelt tensioner?
Old 07-27-2014 | 12:01 PM
LostInSpace's Avatar
LostInSpace
Default Cracked cylinder wall on cambelt tensioner?
Stripped down the cambelt tensioner from the GTS today, this is what greeted me:
Appears to be a crack down the length of the wall at approx 5:30 o'clock.
The tensioner had some residual oil, but was effectively empty. Doesn't look like a score mark as there's no wear and it runs the length to the cylinder wall, not just the range of movement for the tensioner arm.
Anyone seen this before and care to speculate the cause
Old 07-27-2014 | 12:37 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Looks too perfect to be a stress crack. And, as you say, it extends the full length of the sleeve. [scratches head]
Are you able to get the piston out?
Old 07-27-2014 | 01:27 PM
LostInSpace
Piston came out with the lightest of pressure. No mark or damage on the piston wall that I can see.
Old 07-27-2014 | 01:38 PM
M. Requin's Avatar
M. Requin
That looks like a manufacturing defect in the tube the sleeve was made from.
Old 07-27-2014 | 02:55 PM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
That's very common. As long as it's still round and smooth I would not worry about it
Old 07-27-2014 | 03:21 PM
PF's Avatar
PF
Had the exact same crack on the 89 GT I used to have. I put i back together and never had a problem with it.
/Peder
Old 07-28-2014 | 01:57 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
put it back into service it will function as designed.
I suggest to refill it with STP oil treatment, and use Hondabond 4 on the tensioner gasket.
Quick Reply: Cracked cylinder wall on cambelt tensioner?
