DRY-CLEAN Your Engine
"Dry ice in the form of small pellets (1,5 and 3,0 mm for automotive use) is loaded in a specialised machine and fired at the dirty object at speeds of up to 360 km/h."
http://www.carmag.co.za/technical/dr...your-engine-2/
I haven't used it, but I don't know if it can cut through old grease and grime like a high strength solvent can.
Best way to clean the engine,
with it cool use a rag and some brake cleaner and needle nose pliers
CRC Pro strength degreaser. It wipes off and does not need to be rinsed with water, leaves no residue, and smells not unpleasant. It foams up, and the can seems to last a long time. Went through many cans lately, and you need to scrub a bit with a brush on heavy stuff. I would end up spraying, brushing, repeat as needed and a final spray and wipe off.
My big deal with cleaners is the stench of most of them and the mess that is created.
As far as rinsing on the lift: Heavy plastic painter's dropcloth formed into a swimming pool works OK for containing the runoff. The grease and solvent residue is really unsuitable for storm drain disposal. If I don't have a lot, I capture it into a bucket and let the liquids evaporate off, leaving a paste of whatever scum I was removing. Again depending on how much, it usually goes into my waste oil drum. The sand and dirt parts are usually left on the plastic as the liquid runs off, so that goes into regular trash for relocation.
Warning,: Harbor Freight blue plastic tarps are not waterproof enough to use for this. The seams leak, and anyplace there was fold is a canditate for leakage. I did all my pre-TB cleaning and fluid removal on one, and found a slimy mess underneath when I started gathering the 'contained' fluids into the bucket. Not real good. Had to wash/rinse/vacuum the slime up; I really don't want that running into the driveway.
Someplace in the James Morrison Euro85 thread there are a few pics of the pre-lift period engine bay cleaning prep, with tarps funneling into buckets on the driveway slope. That was my first try with ZEP orange degreaser from Home Depot, by the way. I needed to clean the front of the engine for timing belt surgery, and did some of the top at the same time. Lack of rinse capacity limited the scope of cleaning to only what was really needed.
You know how it is with a new garage floor- don't want to muck it up! I did and used a cleaner in a purple jug (forget the name right now) at full strength to clean the mess and was amazed at how well it worked. Even got the chewing tobacco stains off the slab from the contractors, haha. Good info though about the tarps, something I will consider when I do everything underneath. I hate grease, dirt.
Should catch most anything unless you use a hose & lots of water. Size is aprox 2 x 3 feet each.
They are also useful for cleaning parts in. You can also use them to drain your block- they hold 20 gallons. Available @ Home Depot usually in the area that has the cement sacks.
http://www.homedepot.com/p/Plasgad-L...ct_description
