Reinstalling transverse crossmember bolts
Making progress on motor mounts job. This morning lifted engine at front and removed the two transverse cross-member bolts.
Both sides needing tapping out with hammer and punch once the nuts were off. I suppose I will have to use same to get the bolts in place on re-install. What concerns me is that on the RHS the aircon compressor gets in the way of being able to take a swing directly at bolt with hammer, let alone fit punch in there.
What alternatives are there for persuading that bolt to go back in when the time comes? I'm experimenting now and I can't push it back in even though no other crossmember bolts are off. Would lubrication in that crossmember hole help? The bolts came out looking remarkably good after 23 years - pretty shiny.
Adrian
Adrian
You have to make sure the cross member is lined up. I know other people have had a hard time getting these back in, but the 2 projects I have done they slid right in. I did put anti seize on the bolts and used a floor jack under the cross member to line up the bolt holes.
Hope that helps.
Hope that helps.
Which bolts are these? The cross-member has two on each end.
In any case, clean the threads. This shouldn't be so hard. It's one thing to have them come out hard but on re-installation with lots of force you're likely to cross-thread the bolts, have them jam or strip, and really be in trouble.
Thanks that's a good idea on jacking x- member into place. What worries me is that I've only just taken bolts out and x-member is as well lined up as it will ever be as no other bolts removed. Even so I can't insert RHS bolt and there's not much room to "persuade" it!
I will use anti-seize on re-install
I don't think the hole through x-member is threaded so the bolt should slide through when everything aligned. I will clean up threads and get new nuts for reinstall
Ahh. The "Evil" upper bolt. Once the others are out, there will be a bit of "wiggle room" in the crossmember. There will be a place where the go in without a struggle. Put them in first.
I had to use a hammer to "persuade" them to come out, but it really wasn't an issue getting them back in.
Team Owner
when you get the cross member bolted on .
Then you will fit the side bolts,
use a long pry bar and place it on the cast section of the exhaust manifold,
then gently pry the link downwards,
then the bolt should easily slide into place.
Before inserting the bolt use a light to see that holes are lined up with the prybar being used
Thanks Stan - I will take a look tomorrow and make sure I understand how to apply your instructions.
Great tip on the alignment light!
Adrian
Adrian
