Which engine lift point for motor mount install?
I've got an engine support beam for raising engine from top - it has pair of hooks/chains.
Should I attach at the single lift point in centre that the ignition leads bolt to as they crossover (S4), or use the lift points at rear left and front right if can covers that look like they were designed for this?
Thanks, Adrian
Thanks, Adrian
Archive Gatekeeper
Just use the single ignition wire bracket on the waterpump:
![](https://webfiles.uci.edu/redwards/public/Engine%20hoist%20bar%20in%20action%208-19-06.jpg)
[QUOTE=Rob Edwards;11496067]Just use the single ignition wire bracket on the waterpump:
While it is completely correct, without the context or the picture that statement just sounds so completely wrong.
