Front spring washer diameter needed
I think I may have had a moment of less than optimum brain activity when I put my coil-overs together. What is the diameter of the two upper washers (#9) supposed to be? I am assuming they should be larger in diameter than the washer that goes on the rear springs (#16)?
Cheers!
Carl
Cheers!
Carl
Archive Gatekeeper
Front shock spring top washer 78-95 is 55.61 mm, give or take. Holler if you need me to pop the cover on the rear and measure it.
![](https://webfiles.uci.edu/redwards/public/Front%20S4%2B%20Spring%20assembly%20top%20washer%20OD%2055-61mm%207-4-14.jpg)
Team Owner
I think they are all the same size, not 100% sure
Thanks Rob and Stan!
I am certain the front ones are the same diameter but I have 4 large ones which I assume is #9 (front upper and lower) and 2 slightly smaller diameter which I assume is rear #16. If anyone has easy access to the rear ones I would absolutely love a picture or measurement to confirm if I am experience a brain fart or not. If I managed to put one smaller in the fronts then it won't rest properly on the inner (hidden) rubber lip on part #8...which means I get to practice removing them....arrgh!
Happy 4th to everyone!
Cheers!
Carl
Cheers!
Carl
Archive Gatekeeper
Rear 78-95 shock top washer is 48-ish mm:
![](https://webfiles.uci.edu/redwards/public/S4%2B%20rear%20shock%20top%20mount%20washer%2047-93%20mm%207-4-14.jpg)
Team Owner
After looking at the part numbers they are not all the same and Rob has confirmed this,
the fronts all take the same size,
the 2 rear washers are smaller diameter
