GTS intake tubes question...
Hi !
2 hours went by searching on rennlist (and elsewhere) about changing my GTS intake tubes( poorly made, with an iron spiral covered with a stupid foam...and ridicolous price) with "old style" tubes from S4-GT.
Are S4/GT tubes interchangeable?
Do S4/GT tubes affect performance?
last question(I bet every GTS owner asked himself this question):
WTF were Porsche engineers thinking when they designed that costly tube-shaped pile of misery ?
thank you for your replies and time.
Francesco
Francesco
Get four Mercedes plastic tubes with part number 117 094 03 82 and two 3" diameter pieces of black silicone hose. Looks like it could come from factory and lasts long time.
![](https://rennlist.com/forums/attachments/928-forum/162389d1168136910-end-round-1-mb-intake-hose-83-928-m28-21r-s.jpg)
Or 76mm in Europe. MB tubes have different size ends. One end fits right over factory plastics at fan thing and filter cover same way as stock factory tube. Other end outside diameter it mm or two larger than 3" silicone hose inside diameter. Hose stays on nicely. Only thing needed is to make hole to two tubes for cambelt cover breather.
The MB tubes are exactly the correct diameter, and fit perfectly. You just need to make a hole in each of the front pair to fit over the outlet from the front cam covers, and to cut a slight triangle out of the end of two, so they can be 'inserted' into the other two to form a continuous tube.
I bought the MB tubes from Roger 4 years ago for my GTS and they're holding up great. If you do go that route, you'll need to save/reuse the rubber doughnut end pieces from your GTS tubes though. As good as they are, if someone ever sources an OEM looking tube that doesn't suck, I'm in for a pair--I'd like the engine to look stock.
Thanks Gary.
Basic Sponsor
I sell the aftermarket Mercedes tubes (not HomeDepot 8>)) for $75 the pair. We use a silicone joining tube that is available in red, blue or black.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Archive Gatekeeper
That's a great price, Roger, given that the '87-91 S4 intake tubes went completely ballistic in the fall of 2013 and are now what, $140 each?
I just went with the standard tubes after my top end refresh.
No change in noise or performance over the GTS tubes. My understanding is that the insulation on the GTS tubes was intended to reduce intake air noise?
![](https://rennlist.com/forums/members/randy-v-albums-gts-picture15177-7.jpg)
Randy, what is your black hose running just above your oil fill but below the cross beam and runs from once side to the other disappearing underneath both valve covers?
Archive Gatekeeper
Bryan, that's a factory 'late' GTS breather hose- connects the two front breather elbows to equalize crankcase pressure between the two heads.
