I pulled the 2 bearing assemblies out of my torque tube hoping to press the bearing rollers out for replacement. As opposed other member's experience, my rollers appear to be embedded in the large metal/rubber ring. On both sides a lip appears to prevent pressing them out.
Can the bearings be pulled out of that type of assembly? If so how? If not, where can I get a replacement?
Michel
89 928 S4 auto
Wow! I wrote that a long long time ago! 12 years to be exact.
And this method works! Thank you for inventing this method and above all, sharing it with us. Here are a couple of pictures of my TT bearing replacement
Great pics, very clear, good documentation on the fix, but.... The if the front bearing is too far back, it will allow increased harmonic vibrations in the unsupported length of the shaft between the front bearing and the flex plate clamp. The front edge of the bearing outer ring (with the rubber) should only be about 4 inches from the front edge of the flange of the TT. This was the original position of mine before it started migrating rearward, the further rearward it got, the harmonic wobble effect increased, exponentially, which aided it the slippage of the flex plate clamp. When I discovered the cause of my engine/drive train vibration I found three major things.
1, the front bearing had migrated 13 inches rearward (noted by the longitudinal marks visible on the wall of the TT,
2, there was visible evidence of the pinch clamp slippage on the splines,
3, the flex plate was fractured by the force of forward pressure of the clamp.
I have come to the conclusion that this series of failing events is not the cause of inadequate clamping force alone, but the minimal surface area of the original bearing outer ring which is only one inch wide. Imagine if you will, the centrifugal force and thrusst of the splined shaft working together, on one end there is a little clamp, on the other is a thin bearing holding the wall of the tube. I'm no physics major, but its easy to understand that a greater clamping force and a larger bearing surface area against the TT wall will diminish the wobble effect of the shaft that leads to bearing migration and clamp slippage.
Reason: editing
And, which is why you should just call Constantine at Black Sea, and be done with the whole issue.
Do a search Michel, you'll see what I mean.
Et, ce qui est pourquoi vous devez juste appeler Constantine à la mer Noire, et faire avec toute la question.
Effectuez une recherche Michel, vous verrez ce que je veux dire.
I rebuilt the tube back in June along with the tranny. The car has log at least 4000km since without a single issue. Neither driveshaft movement nor vibrations were at stake before rebuilt. I found the bearings to be noisy when turning by hands that's all. While at the tranny might as well do them! I haven't considered Constantine so I can't really speak about it.
