Air Pump
I've just installed an x-pipe that deletes the cats so I no longer need the air pump. I'm also just re-building the front end after doing the waterpump and timing belt. I figured that I would just leave the air pump in place and not put the air pump belt on just incase I return the exhaust to stock at a later point.
My question is, is it ok to run without that belt? I have a silly idea in my head that having two belts on each side (AC and Air pump vs PS and Alternator) perhaps balances out the tension on the crank pulley.
