Does your sunroof motor do this?
Another option to a worn clutch is that the screw that you remove to fit the manual sunroof tool may be a bit loose causing decreased resistance on the motor when the roof is fully open or shut.
Try tightening that and see if it helps. (My one needs to be quite tight to stop the motor quickly).
Myles
Myles
Cottage Industry Sponsor
When opening my sunroof using the one-touch function, the motor continues to run for 3 or 4 seconds after the roof is fully open, as if some actuator that shuts off the motor is not working properly. It kinda sounds like it grinds down to a halt.
Is there an adjustment of some kind that I need to make to a motor shutoff switch of some kind? Or, is this normal?
Yes, there is no one-touch close--just like the windows. Does anybody know if the clutch is serviceable/replaceable separate from motor?
Electron Wrangler
Just unplug the single pole connector on the Black & Black/Yellow wires on the window controller under the drivers seat. NB There are 2 single pole connectors (the other disables the sunroof).
As with most things - the ROW configuration is just better...
Alan
Not sure if the North American cars have the function where you can simply use the key in the door to close the windows and sunroof by holding in the locking position. I often jump out forgetting to close the roof and like using this feature. I'm sure its also a relay modification?
On the one-touch close option can you easily stop the window by tapping the switch again? In our climate the only time I ever close the windows completely is if there's a chance of rain, otherwise it gets much too hot inside the car ... and I won't even mention a 928 AC's ability to cool down the inside of the car after a hot soak in the sun ;-)
Perhaps that's why Porsche gave priority to opening ...
Electron Wrangler
Electron Wrangler
BTW not many realize that it works from the hatch too... and if you install a KE the right way you can even do it remotely
Alan
