928 Forum 1978-1995
Sponsored by: 928 Specialists
Replacing ignition switch advice
Old Jun 15, 2014 | 12:50 AM
Calgary Ole's Avatar
Calgary Ole
Default Replacing ignition switch advice
What is the easiest way? Should the pod be removed or can it be done from underneath the dash?
Old Jun 15, 2014 | 12:56 AM
Adamant1971's Avatar
Adamant1971
Pod out. It's a good time to change your odometer gear and clean the gauge contacts.
Old Jun 15, 2014 | 01:40 AM
Calgary Ole
Pod has been out a couple times for hvac actuator replacement. PIA but if that's the best way then I'll do it again.
90 s4 so digital dash and no speedo gear!
Old Jun 15, 2014 | 01:41 AM
Landseer's Avatar
Landseer
Battery must be disconnected.
Big sparks otherwise.
Big.
Old Jun 15, 2014 | 02:02 AM
Calgary Ole
Big.
Great advice!
(Rescued a 180pd Newf this winter btw!)
Old Jun 15, 2014 | 02:26 AM
Landseer's Avatar
Landseer
Big pup!!! Is he with you still?
Cold winter down here. Newf's feet got so cold at -17 that we needed to help one back into the house.
Old Jun 15, 2014 | 01:43 PM
Calgary Ole
This is his home now for good. He is a great dog! We find that there webbed paws get packed with snow during the cold winter days that it hurts them to walk.
I am going to do a search on pod removal. I found one a couple years ago when I did the actuators. Can't remember who wrote it but it was quite good. If anyone has it handy....tia!
Old Jun 15, 2014 | 03:08 PM
Randy V's Avatar
Randy V
25 Year Member
The switch can be replaced without removing the pod, just much easier to remove it.
Old Jun 15, 2014 | 06:04 PM
jheis's Avatar
jheis
It also helps to have a really short screwdriver with about a 1/4" wide tip. The switch is held in with two slotted screws that screw in from the back and they can be a real pain to get to.
I ended up cutting most of the handle off of one of those Harbor Fright freebies so that it is about 2 1/2" long.
James
Old Jun 16, 2014 | 12:44 AM
Calgary Ole
James
Thanks Randy and James
I might give it a try. I would like to get the new switch in ASAP. I will have to remove the pod later for a different project but I don't have the parts ready yet.
So 2 slotted screws. Short screwdriver. Probably have to lay out under the dash to reach them?
Old Jun 16, 2014 | 01:30 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Remove the pod bolts but just raise the pod in place and prop it up. No need to disconnect any pod wiring this way. A stubby screwdriver worked for me. A 90 degree ratcheting screwdriver might be easier. IMHO
Old Jun 16, 2014 | 01:33 AM
Calgary Ole
Great idea. I'll give it a try!
Old Jun 16, 2014 | 02:27 AM
jheis's Avatar
jheis
The difficult part is that you can't see the slots in the screws so you have to do it by feel - and since your going in from the back - turning is the opposite of what your used to.
James
Old Jun 16, 2014 | 09:13 AM
jpitman2's Avatar
jpitman2
My question is, are you sure you need to replace it ? I did mine a year or two back because it seemed to be the cause of failures to crank. It actually ran a lot better after the change, so it was worth it. Then it failed to crank again - it was the starter relay all the time....Along the way I cleaned up several contacts on the instrument panel contacts, notably the earths, and now the gauges are more stable.
jp 83 Euro S AT 55k
Old Jun 16, 2014 | 09:29 AM
Indy Rev's Avatar
Indy Rev
The 2 screws are the worst part of the project. I disconected the pod just enough to be able to move it around. A ratchetting 90 screw driver would have been nice. Once you brake the screw free I found it easier to spin it out with my finger and also replace it the same way.
