Maybe a picky point, but... invest in some spray engine cleaner and the garden hose to make the trans gleam. Better to do it before you even drop the pan, getting all that crud before there's the slightest risk of any getting into the sensitive areas once the pan is off. Do it a day or two in advance, helps you identify all the leaks in advance so you don't miss anything.
The car is a lot more fun to work on when things are clean. The effort is certainly worthwhile for me.
didnt thing of that, ill make sure i do that next time. im looking into replacing all my rubber fuel lines so it will be in jacks a few days
