928 Forum 1978-1995
Sponsored by: 928 Specialists
On the way home from SITM, loss of power?
Old 06-08-2014, 02:14 PM
Adamant1971
Adamant1971's Avatar
Received 1,080 Likes on 509 Posts
Default On the way home from SITM, loss of power?
Car is still driving but a loss of power above 3k. Me thinks it's the flappy. No way to pressure test it. If you rev it past 3 when parked, will it move?
Just outside of Roanoke, having a bite.
I guess i will just drive her easy and check under the hood more often.
Old 06-08-2014, 02:27 PM
Leon Speed
Leon Speed's Avatar
I doubt the flappy can cause serious power loss. Maybe torque but not serious. Anyway, it should move after 3.5K revs, it should also open and close as you turn on the ignition. If you take off the rubber cap and attach a piece of tape, you can look under the hood from behind the wheel to see if it moves.
Have you tried switching some 53B relays?
Serious power loss above 3K revs sounds more like a bad MAF or LH. Or fuel restriction, or bad fuel, or incorrect timing, or corroded ignition coils.
Luckily you can cruise easily at 2.5K revs.
Old 06-08-2014, 02:33 PM
Adamant1971
Maybe the power loss is not as serious as I first felt.
Pretty sure the flappy is not moving, I already had the rubber cap off and revved her up and it did not turn.
I will try the tape, so I can see where the tach is at.
It's still accelerates above 3k, just not with the unusual freight train feel.
Old 06-08-2014, 02:39 PM
mickster
mickster's Avatar
My cars flappy is disconnected; power loss compared to other S4s is not huge in comparison driving.
Old 06-08-2014, 02:45 PM
Adamant1971
Tested with a piece of tape, flappy is not turning. Will carry on towards Pittsburg.
Old 06-08-2014, 02:50 PM
Adamant1971
Tested it again,I just gives a very slight twitch. Will need to test vacuumed lines, and the flappy system at home.
Old 06-08-2014, 02:58 PM
mickster
mickster's Avatar
Ah-yup. Could be symptom of large vacuum issue. Safe travels!
Old 06-08-2014, 04:28 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,471 Likes on 1,390 Posts
how much fuel is in the tank? better to run it at half or more
did you remove the gas cap to check for suction?, leave the cap half a turn loose.
did you look at the tank to see if it is collapsed? check the vent valve adjacent to the dipstick this goes bad the tank will collapse.
leave the cap 1/2 turn loose
Old 06-08-2014, 05:04 PM
M. Requin
M. Requin's Avatar
If I am in range and you need help- 434 eighttwothree 2059
Old 06-08-2014, 05:38 PM
James Bailey
James Bailey's Avatar
It is NOT the floppy...I would be concerned it is running on four cylinders....so you have 160 horsepower
Old 06-08-2014, 05:46 PM
Tony
Tony's Avatar
sounds like its timing related..
Old 06-08-2014, 05:55 PM
James Bailey
Timing related is a big potential problem..... huge unmetered air leak is worse at low RPM. Fuel filter blocked is so uncommon...
The cars will run surprisingly well on just 4 cylinders. I would be checking both ignition systems
Old 06-08-2014, 05:58 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Check that the secondary leads from both coils are secure in the distributor caps. If you were recently in the MAF area, verify that the MAF is seated in its boot correctly. Change the fuel pump relay. Verify that the battery voltage is OK (not falling off due to discharge). Verify the connections of the minor positive leads at the battery, clean and tight.
The flappy makes only a very minor drop in power if not activated. It's connected to cannister/stored vacuum, so you should feel real vacuum at the source port on the flappy solenoid with the car idling. Regardless, effect is minor and generally ot a sharp difference you might notice in casual driving.
If one ignition is not working, raw fuel is passed through to the cats. That's a serious risk of fire. Might be coil leads as shared above, arcing from a bad wire, failed transistor driver module on the front apron, or a failing coil, cracked cap.
The symptoms also sound like some that have reported as part of an impending total LH failure. Is yours rebuilt?
Old 06-08-2014, 07:21 PM
Adamant1971
It's seems to be running better, just outside of Pittsburg now.
I'm leaning towards it being fuel related. I'm going to stop shortly for the night. I will check the gas cap and the ignition leads when I get to a hotel.
I'm wondering if it could have been some bad gas?
Anyways thanks for the tips on what to look for.
Old 06-08-2014, 07:23 PM
Adamant1971
No, the LH was not rebuilt, but it is a used unit that was put in the car back in the late 90's.
Quick Reply: On the way home from SITM, loss of power?
