928 Forum 1978-1995
Sponsored by: 928 Specialists
Passat Interior Light Pigtail question
Old Jun 5, 2014 | 01:37 PM
prescott's Avatar
prescott
Default Passat Interior Light Pigtail question
NEWB question. Got new interior lights from Roger @ 928sRUs. Look and feel so much more solid that what was stock in our cars! I want to install these this weekend.
The Pigtail is on the right side when looking at the face of the light. There are 3 wires on the pigtail: top middle and bottom. Which wire from the car goes each pigtail wire?
Thanks!
Brian
Old Jun 5, 2014 | 02:46 PM
Alan's Avatar
Alan
Electron Wrangler
I don't recall, but remove the back & the bulb - with a multimeter test the connections, which one goes directly to one end of the bulb when the switch is off - that goes to the red wire (or in hatch sometimes green wire), the other two are connected to the switch and then the other end of the bulb - connect the one that connects in door switched mode to the Brown/Wire wire (or in hatch sometimes white wire) and the other one for always on mode to the brown wire.
Alan
Old Jun 9, 2014 | 03:50 PM
prescott's Avatar
prescott
Smile
After a little exploration the wiring worked in my 88 S4 when done in this manner
Top pigtail wire - White/Brown
Middle pigtail wire - Brown
Bottom pigtail wire - Red
Butt spliced with shrink wrap with an extra wrap of silicone tape! after this photo was taken.
Hope this helps!
Brian
File Type: jpg
Old Jan 26, 2023 | 09:26 PM
cgraner's Avatar
cgraner
Is this one shown LED?
Old Jan 27, 2023 | 12:56 PM
Zirconocene's Avatar
Zirconocene
It can be, if you change the bulb, but it's not that way natively.
Cheers
Old Jan 27, 2023 | 04:40 PM
cgraner's Avatar
cgraner
It seems that they now have native LED versions:
https://www.ebay.com/itm/185132337685
https://www.walmart.com/ip/iJDMTOY-G...ssat/475845472
Amazon Amazon
Old Jan 27, 2023 | 05:16 PM
Zirconocene
That's a good find, cheers!
