My 1987 S4 Murf stage III install
Prior to getting my transmission sorted I had planned on getting a supercharger. The opportunity presented itself to purchase a used kit from Murf and I jumped on it. Other than basic maintenance and the WP/TB I haven't done alot of work on these cars.
Well all of that has changed
It has been a significant amount of work but I am close to having Supercharger done.
I still have some hoses to trim, I need to add a vacuum line to the blowoff valve and install the super cooler and plumbing.
I'm hoping to have this done by the weekend. fingers crossed
At this point I would say around 25 hrs. Much of this was figuring out how to take things off. Two hours trying to figure out how to put a bolt on the supercharger bracket..LOL. I am going to help Tim revise his instructions ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
He has been EXTREMELY responsive and pleasant to work with. I feel bad bugging him about things but sometimes I had no other option.
It's ALIVE!!! I got everything together yesterday and fired it up. The car immediately fell to idle just like it had before. You can definitely hear that vortex sound.
There was a slight clearance issue (my fault) with the intercooler being too close to the fuel rail. Easily resolved
All that's left is to get the charcoal canister in right so I can get the wheel liner back in.
If the rain stops I'll take it for a drive this afternoon.
On the first drive I ended up overheating the engine. Had the cooling fans reversed.
Test 2 was amazing! The acceleration kept building and I let off because I was already doing 100 before I knew it.
Idle is perfect and runs great around town. Very pleased
So....I need a refresher- do you run larger injectors? Does it come with a reflashed computer, or is it full standalone? Did you have to dial in an adjustable fuel pressure regulator?
Administrator - "Tyson"
The early kits (pre shark-tuner) had boost activated fuel pressure regulators.
It's a 100% bolt on and go kit.
So not to derail- but there is a Murf solution to mounting the kit on 85/86?
Hmm...sell one to supercharge the other....naw, it'd have to be a twin screw and deliver 100HP..
Does seem the Murf kits are the shnizzle, I look forward to hearing this one running!
