More foolishness from a PO
Hi All
Removed my oil tube today only to find it fastened with these lag screws (sigh!)
My question is...time sert my best option here for fixing this?
I know nothing about time sert repair so could someone advise me of exactly what i will need to accomplish this...
...or is there another way?
Thanks as always!
Thanks as always!
Team Owner
please post pictures of the damaged surfaces
Time serts are the way to go, depending on what is going on with the hole. There are lots of you tube videos on how they work.
Team Owner
those holes look slightly damaged.
Drain the oil, plug the opening with a rag.
Then,you have a few choices.
But, I would install timecerts.
Note dont go very deep as you can come out the other side .
I would try a thread chaser first. There should be plenty of threads left to give the bolt enough bite. My 2 cents.
I agree with Stan. Doesn't appear to be extensive damage. It appears that previous owner might have lost the correct bolts and fitted the sheet metal screws in their absence. I don't think those screws were used because the holes were stripped. I would first try cleaning the threads with a tap and see what you have. The bolts don't need to exert much force as you are sealing with an oring.
Do not use a tap! Use a chase - huge difference.
