Greg Brown Fuel Hoses
I got around to installing my Greg Brown fuel hose (the U shaped one in back of engine). It is a work of art. Goes on perfectly. Found a small screwdriver in there that must have been lost during supercharger install.
Received 1,542 Likes
There's a lot wrong with that picture if the fuel system is supposed to be stock. I trust that its all part of the SC install.
But, Yes, Doc Brown's lines are The Ultimate.
front damper swapped with the rear? so fuel feed line is in the back of the picture?
The 'U' line looks like FI line secured with clamps.
I also use Gregs fuel lines and his flex clutch line.........the best
Archive Gatekeeper
Greg has two businesses, Precision Motorwerks and J2 Precision. The latter is his hose and fittings company, which allows him to fabricate weapons-grade hoses for fluid handling. Oil, coolant, hydraulics, fuel. He uses primarily Goodridge components, and keeps a stock of custom fittings he's had built over the years for many 928- and fussy German car-specific fittings.
Correct very high quality hoses fittings assembled with extreme attention to details by someone who knows where they go, what they do, and what happens if they fail......
More line ****. Four sets of Doc Brown's fuel lines and a set of oil cooler lines (normally you don't get the re-plated stock bits, but I did a volume deal and sent Greg cores):
Apparently rennlist mobile didn't upload all my photos. There supposed to be three.
Damn mobile app. Ever since some big change it really sucks. Tried posting a picture. Didn't work this time.
