928 Forum 1978-1995
Sponsored by: 928 Specialists
Pod knob lights
Old May 15, 2014 | 08:47 PM
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by MjRocket
Alan
So do you see any issue with using the LED bulbs, in regards to them brightening/dimming or otherwise functioning as originally intended?
Yes.
As with swapping any of the instrument to LED's the stock dimmer will give you crappy results wrt dimming, you can have full on OK but not much dimming beyond that (certainly very non-linear)
Get Ed Scherer's great PWM dimmer and it will work as well for these as it does with everything else. I'd not do instrument LEDs without a PWM dimmer. \
The bright modes should still work fine.
Alan
Old May 15, 2014 | 08:53 PM
MjRocket's Avatar
MjRocket
Originally Posted by Alan
Yes.
Alan
Do you have a link to said dimmer?
Hard to search on my phone.
Thx
Old May 15, 2014 | 09:00 PM
Alan's Avatar
Alan
Electron Wrangler
https://rennlist.com/forums/showthre...eferrerid=6055
Old May 15, 2014 | 09:02 PM
vanster's Avatar
vanster
I installed LEDS using green for green and red for red etc. Also I eliminated my dimmer a long time ago. Sometimes the switches are a bit bright but better than stock, I also swapped out the prisms for LED's. They were $50 and came out of Bangkok. I opted for the blue, which gives the same cast as a new VW.
Might change them for a white or red set in the future.
Old May 15, 2014 | 09:07 PM
Ladybug83's Avatar
Ladybug83
Alan,
Any suggestions on how to rehab my switches as originally intended with this post? Sounds like the leds will look weird (too bright) without the dimmer and with all of the other original lights. If not maybe I'll just buy new (used) switches.
Old May 15, 2014 | 09:33 PM
vanster's Avatar
vanster
I have an entire box of switches, even an extra set of gauges. I tried everything.
Maybe I'm because I'm old and can't see but I wanted a brighter panel and the LEDs without a dimmer works for me.
I bought a new 86 300E and it's gauges were dim. It's a German thing in the 80's I believe. Dim or Tokyo at night, your call
Old May 15, 2014 | 09:38 PM
MjRocket's Avatar
MjRocket
Alan
Just read up on the dimmer.. Sounds perfect!
Much appreciated.
Old May 15, 2014 | 10:36 PM
SeanR's Avatar
SeanR
Kinda hard to get a good picture but here are a couple I just took.
Alan is right, you won't have the dim function but if that doesn't bother you don't worry about it. I did install Ed's dimmer module and honestly have not used it since I installed it. I have installed a bunch in other cars and they really like having that feature.
Old May 15, 2014 | 10:37 PM
Alan's Avatar
Alan
Electron Wrangler
Originally Posted by Ladybug83
Alan,
I don't think you should get new switches - these cannot logically be causing your problems (one maybe... but not three).
Do your variable dash lights work: pod illumination, HVAC etc?
If not you need to fix that first. If yes there must be a wiring issue to the pod switches
Alan
Old May 15, 2014 | 10:59 PM
MjRocket's Avatar
MjRocket
Originally Posted by SeanR
Kinda hard to get a good picture but here are a couple I just took..
Those look Really Good Sean, Thanks for taking the time to snap the pics.
I'm gonna go ahead and order those as well.
Old May 15, 2014 | 11:46 PM
GrumpyFinn's Avatar
GrumpyFinn
I changed everything to leds also, to keep approximately the old brightness you need to use resistors, I bought mine from radio shack. There's a great write up online how to swap them. I also added lights to my auto-gear shifter so that the center console including ashtray is blue, rest I stayed with factory colors, there was also a diode or two that I needed to add.
Old May 16, 2014 | 02:19 AM
Ladybug83's Avatar
Ladybug83
I'm convinced. Ordering LEDs nnnnnnnnnow
Old May 16, 2014 | 02:23 AM
Alan's Avatar
Alan
Electron Wrangler
LEDs will not solve any functional problems you already have.. any answers to the questions?
Alan
Old May 16, 2014 | 02:45 AM
MjRocket's Avatar
MjRocket
Alan
Thankfully no malfunctioning issues here, for me its just a matter of getting a bit brighter allumination. With new LED's along with the dimmer module looks like I should get the perfect desired affect.
This thread has been very informative.
Thanks guys
Old May 16, 2014 | 03:07 AM
Ladybug83's Avatar
Ladybug83
Oh yes sorry Alan, I get overwhelmed with all the posts sometimes.
All of the other lights function properly. The other pod switch lights, illumination on gauges, hvac, doors domes etc although the hvac , radio and other center console stuff is all unplugged currently. Also all switches on pod, doors, center console work properly.
I've cleaned some of the body grounds but not all of them yet.
Only the trip reset is dim and the flasher is dim in the out position. I changed out the bulbs (37's) for new ones but same results.
Could I have put too much deoxy in there maybe? I just put in a tiny drop but I couldn't really get in there to wipe it afterwards like the directions call for. I lightly deoxyed the tabs and connectors behind all the pod switches too. It sounds like I doused everything but I didn't, I was sparing and careful with the deoxy. Also I cleaned up all the tabs and connections with a fiberglass pen.
Tomorrow I'll double check the wiring behind those two switches and double check to make sure none of the loose wires (radio, hvac etc) are touching or grounding out. No fuses have popped. I'll double check the ground under the pod to make sure it's tight. What am I missing?
